Question about Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
Hi I have a Central Pneumatic model 94667 air compressor that was working fine, now it will not shut off when it gets to the usual shut off pressure. thanks. George.
On this particular issue, I agree with trpabc, given the description; you most likely need a new pressure switch. It's unlikely that it suddenly got out of adjustment, therefore a new one is in order.
nobody794:
I had the same issue you had, and after reading your post, I went down to my garage to investigate... Turns out the valves in the compressor are just simple reed valves, like on a 2-cycle engine, and my inlet valve had some gunk baked on it, which didn't allow it to shut all the way, giving me only 60 PSI. I cleaned all the parts with a wire brush, then polished the surfaces with 1000 grit sandpaper, and it runs like a new one again. :o) I don't think you can actually crack those thin sheets of metal...
Posted on Jul 13, 2009
Make sure it is actually achieving full shutoff pressure. I had the same compressor and had a valve crack and the compressor would run nonstop but never got above about 40 psi.
Posted on Jun 18, 2009
  • 234 Answers
You probably need a new pressure switch.
It is possible that you can adjust or repair it also.
It is best if you unplug the compressor before working on the switch to prevent shock.
There is usually a nut on a threaded rod that forces against a spring.
If you have too much pressure, you usually back off the nut and it will shut off at a lower pressure.
On a single stage air compressor 110 - 120 psi or less is appropriate.
Posted on Apr 15, 2009
94667 central pnuematic i have. need to know how to remove pressure switch from machine. the red button on top of switch will not come off. help please??? and thanks in advance for all help
Posted on Jul 04, 2011
  • Charles L Green Jul 31, 2011
    the red button does not come off. right next to it in a hole that is probably filled with gunk is a small phillips head screw. Loosen it and the whole thing including the red button comes off
Central pneumatic #94667 compressor needing pump and motor where can I get them at
That unit was sold by Harbor Freight and is no longer made. Why do you believe you need both the motor and the compressor?
Jan 27, 2017 | Air Tools & Compressors
I have a Central Pneumatic 38898 pancake compressor that will not shut off when the pressure reaches pre-set PSI. I have replaced the pressure switch but to no avail...HELP!!
There must be a blockage on the fitting where the pressure switch goes in that stops the air pressure from reaching the regulator. Try taking the switch off and turn the compressor on and see if air comes out the hole
May 23, 2015 | Air Tools & Compressors
21 gal vertical Model 94667 will not fill tank.
Could be piston rings too. Have you looked here? http://www.centralpneumaticaircompressors.com/buying-central-pneumatic-air-compressor-parts/
Oct 14, 2013 | Air Tools & Compressors
My Central Pneumatic (mdl 94667) is limiting its output to about 50 psi and below. I am able to adjust it lower but it will not go any higher. The tank pressure is always well over a 100psi. Any...
It sounds like the regulator you use to adjust the hose pressure is not working properly. Sometimes they can be affected if dirt or rust particles get into the regulator. You might be able to disassemble and clean it although some regulators are quite complex and require knowledge and insight in regulator repair to perform. It may also be the regulator is defective or worn out and needs to be replaced. Given the cost of the relatively low cost of the compressor it was likely not a very high quality regulator to start with and needs to be replaced.
Aug 09, 2012 | Air Tools & Compressors
I have central pneumatic 21 gal. air compressor. The unloader valve is broke. The power switch is a fenwai model: fw-10. Where can I buy a new unloader valve?
If you should mean the switch that is pressure controlled that turn the compressor on and off- that is a fairly universal replacement piece, As is the power switch itself
If you needed that specific part, your best bet is Harbor Freight tools who owns the Central Pneumatic domain.
Feb 14, 2012 | Air Tools & Compressors
Hi, I have a Central Pneumatic air compressor model 94667. The start capacitor burned, so i replaced with a similar size cap. It went fine for 3 minutes and the new capacitor got smoked and started to pop....
We get many chinese compressors with burned capacitors. Most seem to use a 140 uf 250v ac metal run cap.(fairly large metal ). The cap will test bad but not look burned. The motors look pretty crude in the way that they are wound (no start winding) and varnish used on the wiring will not take the heat like other motors. Most likely faulty windings. If you try another cap (or two caps to make value)make sure that the voltage is 250 or higher and run type (metal or light color plastic, not the black start caps) (the higher the voltage the better the quality of materials used ). If the checkvalve is faulty at the tank, the motor will have a higher load at start and run (with out start winding motor works harder to start, if all components are not working correctly, motor /cap will overheat ). Check before next test. Good luck
Sep 26, 2011 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
I have a central pneumatic compressor 21gal 2hp a couple years old the unit runs but will only pump up to 75psi and keeps running and does not build more pressure.It was building up to 110psi and then it...
Its the pressure regulator, if you discharge the air and can set the regulator to a lower psi, and it pumps
to that psi. you will have to replace that part, make sure to have make, model , serial# of compressor
so that the correct part can be fittted to you compressor. good luck!
Jul 31, 2011 | Air Tools & Compressors
Central pneumatic. It will not compress to more than 20 pounds. Doesn't seem to leak.
Central Pneumatic is a Harbor Freight Tools brand, and they are usually pretty good about working with you if you need to do an exchange. Get ahold of your local Harbor Freight store or go to their website for more info.
Aug 18, 2010 | Air Tools & Compressors
What type of oil for central pneumatic air compressor model number 94667
It should use 30 weight mineral oil, or 30 weight motor oil.
Aug 01, 2009 | Air Tools & Compressors
Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
3,732 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
