Question about Acer TravelMate 2201LCi Notebook
Locked out i was trying to reset the password to my user name and when i turned the laptop off and cut back on i was locked out completly now when i turn the laptop on i have a black screen with a small picture of a laptop with a key on the side of it, in the upper left corner i tried to press escape and i got an x in the box then i tried typing and i got dots as if i were typing a password but my password would not work
    Sergeant:
  • 457 Answers
Are you talking about the bios password thats the one at the first instance. If you cant get in the only way is to remove the battery inside for an hour or so it resets and allows you back into the setup again?
Posted on Sep 14, 2007
SOURCE:
When I turn my laptop on it won't. Let me log in
Hello
With any password issues, be sure you do not have your CAPS LOCK on and, because this is a laptop, be sure the NUM LOCK is not on either. NUM LOCK activates the number pad on the letters of the keyboard and can easily cause login issues.
With both off, type your password in the USER NAME field and make sure it appears correctly (this will show you what you are typing and how the laptop "sees" what you typed). If this is correct, delete this, enter your user name and then re-type the password and see if you can get logged in.
If this fails, you may need to use a "password reset boot disk" to boot your computer up and reset your password. Let us know if you need help with that step.
Oct 30, 2013 | Packard Bell Computers & Internet
I have a Lenovo A3 series all in one desktop computer and it is not recognizing my password and I am locked out. I put myself on as administrator and the computer was turned off before I backed up the...
first make sure the caps lock if off/on whatever applies the password when you typed it in
Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings
as well as the password and you'll need to re-enter all settings.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
hope this helps
Feb 02, 2011 | Computers & Internet
Locked out of Mac Osx can't remember admin password and have no disk to fix and clear it all to reset password
Turn the computer on Hold Command + S Wait till it enters what is called Single User Mode Type: mount -uw / hit enter Type: launchctl load /System/Library/LaunchDameons/com.apple.DirectoryServices.plist hit enter Type: dscl . -delete /Users/"yourusername" AuthenticationAuthority hit enter Type: passwd "yourusername" hit enter Type a new password Then retype password. type: exit then reboot
If you don't know your username before you type the dscl command type: ls /Users and find your account and use that name for the user name.
Jan 29, 2011 | Apple MacBook Pro Notebook
When i type in my password to unlock computer it says user name and password is incorrect
The user name or password is incorrect. Verify that CAPS LOCK is not on, and then retype the current user name and password. Or you must be trying a wrong password.
Try reseting password using boot disk
Jan 09, 2011 | Dell Studio 1737 Laptop
My acer laptop is locked because the password is incorrect . How do i open the laptop without the password
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc, which is created in advance ( before you lost password ).
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Recovery Tool .
4. Re-install. Will lose data.
Nov 23, 2010 | Dell Inspiron B130 Notebook
My sanyo zio with cricket wont unlock i did the pattern wrong to many times and my gmail account says invalid password or username but i can log in gmail for my laptop no problem.
Everyone says to do a hard reset, DONT. All you need to do is put your Google email in the user name box then put the word "null" in the password box. Once that is done it will ask you to to make a new pattern and then everything is back up and running. I went right in turned off the pattern lock, I never want to see it again. Also it might take a few trys to put the user name and password in. The second try worked for me.
Sep 24, 2010 | Cell Phones
How do I retrieve my password so another user can use his laptop?
If you don't remember your password the best thing to do is to reset the router.
1. Turn off your dsl or cable modem. Keep the router plugged in to the wall.
2. Find the reset button on the back of your router.
3. Use a pen to press the reset button.
4. Hold the reset button down for about 30 seconds.
5. The lights will flash on the router.
6. Turn your dsl or cable modem on again.
7. Reconfigure your router. It will be set to the default user name and password. User name should be blank and password is "admin" without the quotes.
Dec 27, 2009 | Linksys Wireless-G Broadband Router
When I change the web port and reboot the router, I can't access to that again
You can reset it to factory default settings. There should be a very tiny hole at the back of the router. Using a paper pin press and hold on a switch button inside the tiny hole for at least 10 seconds and then release. Make sure when you do this router should be ON. After the reset, turn it off and then turn it ON again. Connect your laptop or desktop to it and now you should be able to access it. Remember to use defualt user name and password. They are usually admin / password OR no user name and password is password.
Give it a try.....
Jamil
Oct 03, 2009 | D-Link DI 514 Wireless Router (DI-514)
LOCK LAPTOP IBM
try going into safe mode. Shut your computer off completely and then turn it back on, when you do start tapping f8 and then choose safe mode with networking. Once your system comes back up see if you can get into any user account. If you can press the start button and click the picture at the top beside your name to enter the user accounts screen, then press the home button, and click on the administrator. from here you can have the option to remove the passwords. If you cant get into any accounts in safe mode you will sadly have to do a recovery, which entails reinstalling windows.
Jan 24, 2009 | IBM ThinkPad A21m 2628 Notebook
Acer TravelMate 2201LCi Notebook Logo
114 people viewed this question
Ekse
Alun Cox
