Question about Acer Extensa 4620 Notebook
How to turn on and use the cam to take pics
There is nothing in these 4 different books!
How do you turn on the cam
On my Insprion 17,I have a camera icon,i click on then the web cam central comes on,i also have skype and on my face book.At the bottom of your screen to the right is a arrow pointing down,click their and find your webcame pic and change settings where it is now seen at the bottom,mine is.
May 25, 2015 | Dell Inspiron 1545 Laptop
What needs to b done if a 1.6L suzuki engine was accidentally cranked one short/quick turn while the timing belt ra's removed? ?? Haynes book only mentions NOT to turn engine w/belt off, but says NOTHING...
wOW NO YEAR STATED, 89-99> n o caar stated either,
so I guess G16a or G16b engine.... why must i guess.... lots of 1.6 by suzuki made.....
nothing, its free running, most G16s are.
cant speak for all 8 cams sold world wide, but stock USA
its free running. why not put the crank at TDC #1 firing
and turn cam by hand and feel, (reality) look ma, no hitting....
that warning is just Haynes (junk book) stating what is printed
on all real SUZ. OEM FSM books, it states this.
http://www.fixkick.com/t-belt/interference.jpg
and is a worldly warning, on all engine they sell world wide all 56 engines sold.
most G16 are free running SOHC , usually are and rare DOHC.
most authorities, all that ive seen and seen most all mimic
the above factory warning, but what else can they do..
they read it and its CLEAR , no?
now your question, sure it dont say what to do
after all they dont know where you left the cam,
if super paranoid, (been there)
we do this,
put crank TDC, mark, (fires every 180 degrees it does)
the turn pulley to 90degrees, this puts all pistons 1/2 up.
now drop the head on to block with , cam cog with E mark at 12pm.
this is #4 firing.
now back the crank up CCW 90%
now #4 is firing.
easy huh> ?
note how the G16 has 2 heads, and are done DIFFERENTLY.
http://www.fixkick.com/t-belt/tbelt-index.html#Tbelt-main
if not paranoid?
put crank to TDC mark, 0deg
put cam cog to E mark up(16v). or pimple mark up(8v) 12pm
there is a 12pm mark on top back of cam cog
this is #4 firing, an is where all G16s are timed. (ALL)
end story.
there are false marks ,fully documented in link for 4 engines.
(they changed marks 4 times)
Mar 16, 2015 | Suzuki Cars & Trucks
I have a 1993 Subaru Loyale, front wheel drive (2-wheel). I pulled the engine, a 1.8L SOCH (according to CHILTON Manual) series 4 (if I remember correctly). I took a 1.8L series 5 from a 91 Loyale, 4-wheel...
I had a similar problem with a ford taurus, had good spark at the coil and sparkplugs, fuel pump, working, fine, computer fine not showing any codes, the problem was the timing, the timing belt went out, most timing gears will have a dot, an x or some other symbol, this works for all cars to set the cams to top dead center, remove the number one sparkplug and either bump the motor or turn the crankshaft pulley until the number one piston rises to the highest point, I usuall insert a long clear fuel line that I can make marks on it so that I can check the highest point, when the number one cylinder is at its highest point, the cams will be at top dead center,even if no marks are shown. if you turn the crank by hand, make sure one side of the battery is disconnected and your car or truck is in neutral with wheels blocked. good luck!
Aug 10, 2011 | 1993 Subaru Loyale
Hi, i gave the same problem of the cam' asking me (on the blue screen) to either turn the cam' off or format the card, (which will erase al the pic's and i dont want it to happen) on the other hand, i...
you should be able to go through the card manufacturer and get "recovery software" that will help you get the pictures back off the card. It is likely that the card has gone bad.
Mar 14, 2017 | Olympus i:robe IR-500 Digital Camera
My coolpix s9 cam will not transfer pics from cam..i would use a card reader but the pics are on the cams harddrive and not the sd card...please help!or does anyone know how to tranfer pics from cams...
You can copy pictures from the internal memory to a memory card by selecting "Copy" from the Playback menu.
Press the MENU button to bring up the main menu, then select the right-pointing triangle to get into the Playback menu.
Jun 28, 2010 | Nikon COOLPIX S9 Digital Camera
HOW U FIND THE MARKS TO PUT THE CAMS CHAIM ON GOOD POSITION. SEND PIC
go to autozone or advance, you can look at pic. in haynes manual. No cost to look, just if you buy the book.
Feb 17, 2010 | 2000 Hyundai Accent
Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Mar 11, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
The image changed after putting it in the computer
sounds like a white balance problem! go into menu to adjust white balance
Dec 07, 2008 | Cameras
2001 chrysler concord 2.7 liter timing set
I have a similar problem. I just replaced the water pump and now the POS wont start. Like it is not getting fuel>
Aug 04, 2008 | Chrysler Sebring Cars & Trucks
Taking a pic
there is no smudge tool in image ready :)
Rubber Stamp and Dodge and Burn tools are also not there
try to send the cam model and i ll try to find some useful software for tranfsfering pic
Jun 16, 2008 | Logitech QuickCam Express Web Camera
Acer Extensa 4620 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
