Question about Toshiba Satellite M30X Notebook
VHS TAPE ONLY RUNS IN FAST FOWARD AFTER PUSHING PLAY
The video comes on but everything is fast forwarded.
  • 1 more comment
  • ln06 Apr 14, 2009
    I guess I need to explain that I am using a VHS tape on my VCR player and when I put it in, it runs fast forward speed without any help. Do not know why since I took the home video with my ordinary camcorder.
  • ln06 May 11, 2010
    Sorry, I am new to FixYa and I guess I posted a question to the Toshiba computer section. What I wanted to do was ask a question about our VCR running a VHS tape in fast mode. I will repost this question. Thanks for your reply.
    K. Nejak
  • ultimitloozr May 11, 2010
    Well... First things first: How exactly are you using VHS tapes in a laptop computer?
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
The DVD part of the machine keeps skipping and now just won't play any DVD's.
I push the VHS Cartridge in, it drops down to the play position, the front door opens, the tape comes out, it goes around the chrome wheel that is spinning, but it will not play, will not rewind, will not fast forward. It then shows "Error" and the machine shuts off, with the tape still around the chrome wheel, When I turn the machine back on, the VHS Cartridge ejects from the machine. This machine has been used very little, I loaned it to my Son In Law and it came back with the VHS Tape Deck not playing. I have the machine open, so I can see what it is doing.
Dec 11, 2010 | GoVideo Go Video DVD/VCR Combo
After I fast forward and press play the tape ejects
try pushing stop in between fast forward and play.
Mar 31, 2010 | JVC HR-VP673 VHS VCR
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
VCR sv 670 wont play or fast forward tapes.
Open the bottom Cover, and check the belts.
Nov 29, 2008 | Samsung SV3000W VHS VCR
Too fast playback of video cassette
Initially, I am inclined to think that nothing is wrong. It is just most likely that that particular tape was recorded in a different speed other than what your VCR is capable of playing. This is a form of compression wherein a longer recording/playing time is squeezed into the same type/kind of tape. The various settings are SP, LP, EP or even an XP. Pls click here to give you an idea of the recording time/speed at different settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | JVC HR-J461MS VHS VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
VWM-950
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
Toshiba Satellite M30X Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
