Question about Dryers
Wont start changed glow bar worked for one time dry now wont start. timer runs but wont start
  • steve
    steve May 11, 2010
    Brand and model number please.
  • 72 Answers
Check door latch and make sure it is still lined up properly
Posted on Apr 15, 2009
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
My roper dryer model rgx5634kq2 wont heat. the glow bar comes on and then goes off, other times the glow bar comes on and there is a flame, the timer only advances for certain cycles as well.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 08, 2011 | Roper RGX4634KQ Gas Dryer
Lost glow plug function
Had same thing happen on my New Holland 1630. Took the buss bar off the glow plugs and pulled them out and tested with test leads on the battery. They glowed. Put a volt/ohm meter on the buss bar and turned the key to glow position, no 12 volts present. Checked for blown fuse, nothing blown. Looked at relays. There was a glow plug lamp timer next to the start relay. Wiggled wires going to timer while asking for glow with key. Saw the glow lamp flicker. Took timer out and opened it up. Found a broken solder joint on circuit board resulting in a loose capacitor. Soldered the crack and put back on tractor. That was it! Glow plugs work now.
Dec 04, 2010 | One Step Ahead New Holland Tractor Set
Heater plugs for nissan terrano 2
i have a nissan terrano 2.7 dti heater light not coming on some times dose and some times does'nt and it wont start
Oct 06, 2009 | 2002 Nissan Pathfinder
Whirlpool model LGB6000KQ1 gas dryer runs but has no heat only cool air. The timer when set to timed drying, moves down to off position, but does not shut off. Please let me know what parts may be faulty...
If the timer advances to OFF and does not stop you have a bad timer. It could also be the cause of no heat. Replace the timer first. If still no neat replace the glow bar ignitor.
Aug 24, 2009 | Whirlpool Dryers
Dryer turns on. no heat and timer does not advance?
sounds like glow bar or photo sensor not working properly. should be access panel to veiw ignition system, if glow bar turns white hot when dryer is started, try to clean face of photo senser and re-start. unplug dryer before cleaning sensor. timer will not start until dryer comes up to temp.
May 15, 2009 | Maytag SDG4606A Gas Dryer
Igniter only glows on permanent press cycle and not timed cycles
I unplugged the ignitor and put the leads from my multi meter into the plug to monitor the signal to the ingnitor. I got 120 volts only when I turned the timer switch counter clockwise or to the permanent press cycle. When I turned the switch clockwise or to the timed cycle I wouldn't get the voltage to the ignitor. While in the timed cycle, I turned the switch counter clockwise and as I started counter clockwise pressure on the switch knob I got 120 volts to the ignitor. There is a little play in the switch and when taking up the play in the counter clockwise direction the switch would engize the ignitor. The timer switch is bad.
Feb 05, 2009 | Hotpoint NVL333GY Gas Dryer
Eastate gas dryer 4-5 years old.
if burner does not reignite and glow bar is lighting up suspect the black coils on valve bad
Oct 24, 2008 | Estate TGDS740JQ Gas Dryer
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
