Question about Acer Aspire 3100-1405 Notebook
Hi my acer 3100 screeen is also dark. When i use the function keys to brighten the screen it does briefly lighten up but then changes back to dark after about 2 seconds?
I have a Lenovo and the screen went dark after i hit the f12 brighten key. Neither the lighten or darken keys work? whats the problem?
It sounds like the screen inverter went out, it needs to be replaced. Take it to a local computer store, not a big corporate store, they will charge you way too much.
Aug 28, 2014 | Lenovo Computers & Internet
Computer screen to dark how do i get to brighten up
Hi
Inorder to brighten up the screen ,try to find the key present on keyboard like "Fn" and also one more which resembles like sun.
This Sun like key will be present in the Function key(F1, F2 Etc)
Press both of the button at same time and adjust the brightness as per you requirement.
And also you can change the same in the power options in the properties where we can change the screensaver
Aug 09, 2012 | Dell Latitude 110L Notebook
How to brighten screen of laptop acer aspire 5610z without keybord ?
May be there is any facility in control panel depends upon the video driver
Jul 20, 2012 | Acer Aspire One PC Notebook
Hp530 screen real dark can see little how to
If it's due to the display settings on your computer, please do this-
Keep on holding down the function key(Fn - probably second key from bottom left) on the laptop and then press F10 key till you get the screen to become brighter.
Please let me know if it works, otherwise, we will have to gothrough a series of steps to resolve it.
Dec 27, 2009 | HP 530 Notebook
HI guys im having troubles with my display, it works, but the light is just no on..when i press that keybord hot key Fn+F6 it just flashes and go dark again..im just typing u with my headlight on.:o)Cheers
back bulbs gone , posssible screeen replacement by the sound of things, search ebay for your make and model , and you can get them there cheap enough hope this helps. also make sure you havnt got the settings down dark try brightening it up in the settings as far as it can go. hope this helps in some way.
Dec 01, 2009 | Acer Aspire 5100-5033 Notebook
I just put new batteries in my calculator and when i turn it on the screen is fuzzy and dark what is wrong?
Probably nothing is wrong. Decrease the darkness of the screen
1.Press [2nd] key and release it
2.Press [ArrowDown] key and release it.
3.Repeat the two steps above in sequence until screen lightens up. You may have to repeat the cycle several times.
Hope it brightens your calculator screen and your day also.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
My laptop is very dark and holding fn and the sun
The Back-light on your LCD screen is bad, your crystals aren't illuminating, so it is dark.... very dark.
You need a new LCD screen.
Sorry.
Sep 24, 2009 | Acer Aspire 5500 5570-4421 Laptop
How do you brighten up the screen? I cannot understand why it is going dark on me. Hope you can help.
there is a function key on the keyboard marked Fn press this key and while holding it press right arrow key for more bright and left arrow for less bright
i hope it helps ur problem pls rate me fixya if i fixed ur problem
Mar 02, 2009 | Acer Aspire 3100-1405 Notebook
Laptop's dark screen is pissing me off
Hi, i have an Acer 5100 and the screen is really dark... can only just make out the screen. I have tried the fn key trick with no luck. I have replaced the inverter and also the screen.... again no joy. Can someone help me please :)
Jul 28, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3100 series. Display screen getting dark
This is such a user error. I had the same problem on my 3100-1718. It was as simple as holding down the Fn key and using the left and right arrow keys to change the brightness... I am a goofball for ever letting this stay dark for a month !
Jun 23, 2008 | Acer Aspire 3100-1405 Notebook
Acer Aspire 3100-1405 Notebook Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
