Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson stylus CX5400 Won't stop jamming!
My Epson printer/scanner simply will not let any paper feed through it without jamming. All the spinner thingies inside are working and there doesn't seem to be anything stuck in there that's causing the jam. I've double checked that the feeder paper size adjuster is correct- close but not snug. What else could be wrong??? Is this device simply a bad quality piece of equipment?
  • seaphoenix86 Apr 16, 2009
    It totally worked! It took a good 20 minutes but it work. Unfortunately, now it won't print. It sounds like it's printing fine but nothing is printed on the paper when it finishes. I'm ready to throw this thing out the window... :(
  • 163 Answers
If the paper isnt being pulled in the chances are that you have a foreign object in the paper path. First of all turn the printer off & disconnect all cables. Turn the printer upside down and give a good shake, with luck the blockage should fall out. If not then you need to be a bit brave, make sure the print carriage is parked fully to the right and out of the way. You will need an A4 (approx) sized piece of stiff cardboard such as the backing from an A4 note pad. Insert this into the paper feed locating it between the feed rollers on the R/H side. Then push quite firmly to overcome the spring pressure, when you feel it push through about a half inch stop and open the printer to see what is being pushed through. Push the card fully through and retrieve the foreign object (I have found everything from paperclips, curtain hooks and even a golf tee!). Push the card through fully and out of the printer. Always remove paper jams etc, in the direction of the paper feed whenever possible as pulling anything backwards can dislodge or break the sensor flags.
Hope this helps. Please take a moment to rate this solution, thanks.
Posted on Apr 15, 2009
  • tigertail
    tigertail Apr 16, 2009
    Carry out about 5or 6 head cleans with a nozzle check between, you should see a gradual improvement. If you still get nothing after 5 or 6 cleans then you need a head cleaning solution such as this one:
    http://websites.uk-plc.net/UK_Inkjet_Car...
    If however you start to see an improvement after 5 or 6 cleans, wait for about 10hrs for the ink to soften and do another couple of cleans. Good luck ;-)
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Says there is a paper jam, my CX5300 Epson, but there is no paper jam! Then it says there is a scanner problem
make sure the printer is off . check for any shredded paper and that the cartrige is down and in its reset position usualy all the way to the right
Feb 10, 2010 | Epson Stylus CX5400 All-In-One InkJet...
I lost my installation software for my epson stylus cx5400 scanner/printer. is there a download site foir this software. i am a student and need to finish research papers and need the device tonight
Please find the driver from the below mentioned link
http://drivers.softpedia.com/get/PRINTER/OTHERS/Epson-Stylus-CX5400-Printer-Driver-54aA.shtml
A positve feedback is expected along with your 4 thumbs
pp
Nov 11, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus cx5 series
Is media transparent? Epson paper sensor think that no paper. Put white stiker at top left and right of media (about 1 cm height and 2 cm width). It's for tricky sensor.
Jun 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
I have a epson printer stylus cx5400 that says error.
Possible hardware failure.
Please turn the printer off. Disconnect it from your computer. Check if there are any obstructions blocking the way of the printhead or the paper feed area. Make sure that the cartridge cover is closed properly. Turn the printer on.
If your unit is not under warranty anymore, please log on to epson.com to find an epson certified servicer near to your area.
Apr 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
1. Make sure the EPSON Stylus CX5400 is turned on and not printing.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
139 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
