Question about Dryers
Should the motor on a gas dryer spin freely by hand. Mine will not turn, so I'm assuming that it bad.
  • steve
    steve May 11, 2010
    If it does not spin...then you have a problem.
  • 490 Answers
You should be able to turn it by hand if not you need a new motor
Posted on Apr 15, 2009
Dryer motor hums but doesn't spin
Sounds like the motor has gone bad.
May 10, 2015 | Amana Dryers
White knight
take the plug
does it make a buzzing sound or do you hear the motor turning
or if you spin the drum by hand it spins freely if it spins freely check the belt and jockey wheels
Dec 08, 2013 | Washing Machines
Air condition motor not going on
check to see if the fan is running if not it has frozen up over the winter. turn off fuses to a/c unit then try to turn fan by hand,if not soak down fan bearings with penetrating oil like PB Blaster keepmoving fan blade back and forth until it spins freely. Then try turning on the power to a/c unit if motor then turns fan freely , shut it down again and use a good coat of a-1 motor oil (ELECTRICAL) on the fan brgs. This should get you through for another year or so. On the other hand if fan will not spin by the motor now but spins by hand then the fan motor is bad.
Apr 14, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
My dryer-gas whirlpool the drum dors not tumble, the heat goes on
try and have the door open hold the door switch and have soem one push or turn the knob on at the same time spin the dryer drum clockwise by hand if it starts. you may need to clean the inside o fhte machine and the motor from any lint build up.or if the drum turns freely and easy you may have a broken belt or it might have slipt of the motor pulley.
Nov 03, 2010 | Dryers
When i go to start my dryer model # aeq6700fso all it does is make a buzzing sound no heat and drum does not turn? i checked the belt is fine and motor spins freely by hand
If the motor is hummming or buzzzing it most likly the motor or a bad wire conection to the motor.
you can try to turn the drum by hand and retry to start the machine.. if this does work, you have a bad spot on the motor and if it does not and you can verify the noise is coming from the motor then the motor is most likley bad.
Oct 06, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Ge electric harmony dryer fan motor not turning just moves side to side 1/4 of an inch back and forth . fan freeweels free, if i spin it buy hand.
with belt off see if motor free spins .the blower wheel should not free spin with the belt on and entire drum will turn with it otherwise you could have a bad motor and a blower wheel
Jan 24, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
My frigidaire dryer glgr331as4 is not spinning
Hi there
i read your report. OK try this tip. Open your dryer and spin it with your hand and its spins freely with no resistance then it's your belt is bad. Try this and let me know how it goes. Ty for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | Frigidaire GLGR331A Gas Dryer
Kenmore Series 70 Dryer cuts off after a few minutes
The bearings in the motor have probably worn out. Disconnect the motor and take it out of the dryer. See if it turns roughly or not at all by hand. Also try and move the post left to right and up and down and see if there is play in it. It should move very little if at all in those directions and should spin freely if it's good.
Dec 17, 2008 | Kenmore 72982 Gas Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
