Question about Kenmore Dryers
It will not automatically turn off when running, the knob does not turn while running.
Hello, I have a Kenmore dryer and need some help. Everything works just fine, but for the knob that will shut the dryer off once it hits the end portion. It will turn fine, but it will not automatically shut off. The knob does not turn while its going so the dryer does not know when to turn off. Can you help me please? Thanks Stephanie
  • sreames Apr 14, 2009
    Thank you very much for that information. I will try that and hopefully it will work.
    Again thanks.
    Have a great night.
    Stephanie
  • Kenmore Master
  • 3,361 Answers
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Posted on Apr 14, 2009
Coils Stay On When Dryer Is Not Running
This is definitely a safety issue and should be referred to Sears. There may be a corrective repair that can and should be made.
Nov 18, 2013 | Kenmore 60172 Electric Commercial Dryer
Push in knob to start dryer. The dry starts, but when I remove my finger off the knob the dryer stops running. Only runs when I hold the start knob in. Kenmore Model: 110.64982300. What is happening,...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Dryers
I need to replace a broken knob for a kenmore 24" stacked washer/dryer Model 11108875279
Their are a total of 5 knobs on the control panel for that laundry center i do not know which knob one you need so this link is for the parts breakdown of the control panel http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-dryer-combo-Parts/Model-11088752792/0582/0152000/P0403242/00001?blt=06&prst=&shdMod=
Gene
Aug 11, 2011 | Washing Machines
I have a kenmore dryer model 96586200 65862. When you turn the timer heat control it won't always turn on you have to play with it to get it to start, but once you find the spot it runs fine until...
There could be a broken part in the dryer knob, see if you can get it replaced. Could be carbon collection too, try to remove the knob and clean it.
Jan 26, 2018 | Kenmore Dryers
When I push the "push to start" button (knob) on
heatman101
Mar 14, 2011 | Kenmore Dryers
The knob won't turn on dryer, it came off...how to start dryer without the knob...it is a 1997
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Mar 08, 2011 | Kenmore 63942 Dryer
Dryer automatically starts when the door is shut
Hello there:
This may not be just a timer issue this could be the door switch that is not operating correctly if this switch fails they will fail in the run position meaning the unit will want to run automatically when the door is closed
so what you are going to want to do is to try to remove the door switch and see if the dryer now runs if not there is the problem simply get a new one and reinstall it now if it is the timer you will have to remove the back panel the panel behind the knobs in the back it should have 8 screws
now after it is removed locate the timer it should be the one that controles the different time settings on the dryer. simply remopve the wires attached to it and mark them so you know where they go and get a new one and install and replace the wires and test if all is good than put the back cover back on ok
Hope this is very helpful for you
Best regards MIchael
Nov 27, 2009 | Kenmore Dryers
Kenmore stacked washer/dryer. Dryer runs fine but washer doesnt
push the knob in then turn it counter clockwise chek the lid switch it may be bad
Jul 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Aug 29, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
316 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
