Question about Toshiba Satellite A75-S211 Notebook
Toshiba A75-S211 memory
My A75-S211 is runnng XP Pro and has a max of 1.5gb. It has board menory of 512 and one slot with 512. So i can relpace the slot 512 with a new 1gb. My question is can add a 2gb and exceed the 1.5 and will it run and use the extra 512kb of menory? I world like to add as much menory as posible
  • joemorreale Apr 15, 2009
    That's what i stated. the question is; could i add 2gb men card, that is greater then rated max ? and can i get any additional proformance by doing so? I'm runing XP PRO not XP home that come with the Toshiba. BTW my base is 512 and not 256.
  • joemorreale Apr 16, 2009
    If anyone else has any insight please let me know, thanks
  • 447 Answers
I'm showing a base memory on that unit of 256 so your max upgrade is 1gb to 1.2gb total.
1GB (1x1GB) Toshiba Notebook 2.5v PC2700 DDR333 SODIMM
Posted on Apr 15, 2009
  • John Elliott
    John Elliott Apr 16, 2009
    According to crucial.com your max upgrade is a 1gb stick, they do allude to the 512 base so you have my apologies for using incorrect info but that still leaves you at 1.5gb. According to what they say you can't use a 2gb module.
Ok i did a clean install of windows 7 ultimate on my toshiba satellite a75 s211 then when i do that i cant hear so i get the latest realtek driver from the toshiba website i install it and i still cant...
Issue with your Hard Disk Possibility of bad sector ..on the primary sector... So Download Partiion Magic and Re- Partionnate your Har drive and Re install you windows
Sep 22, 2010 | Toshiba Satellite A75-S211: A75-S211 Intel...
My Toshiba A75 S211 os XP Home microphone is not working, is there a switch or something else?
Hi, from the "Start" search window: Type: microphone, select to open and configure to specification. "If the solution helped, rating it is appreciated , thanks.
Mar 17, 2010 | Toshiba Satellite A75-S211 Notebook
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
Nov 20, 2009 | Toshiba Satellite A75-S211 Notebook
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    Toshiba laptop a75-s209 maximum memory capacit 2.5 mb
    1.5GB total maxium, if I read the toshiba litature,correctly. So the answer is no, you may not. THe BIOS will only be able to read and use the max it was programed to read.
    http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835414&rpn=PSA70U&modelFilter=A70-S259&selCategory=3&selFamily=1073768663
    Jun 29, 2009 | Toshiba Satellite A75-S209 Notebook
    Adding memory to a a75-s211
    How much memory did it have before you removed the 256Mb RAM?
    If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
    Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
    Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
    Toshiba A75-S211
    You can do either.
    I suggest that if you want to double your memory capacity is to buy another memory module with the same specs and size as the existing one, preferrably from the same manufacturer.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Adding memory to Toshiba A75-S211
    you buy the memory here for a great price or anywhere online instructions are on the page
    it replaces the 512
    http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    How do I replace a keyboard on a Toshiba Satellite A75-S211 laptop computer. I cant see any way to get it out. Also, the power button needs to be repositioned... same problem.
    How to take apart Toshiba laptops. Instructions with pics ... 10 posts - Last post: 21 Mar 2006 Toshiba Satellite A70/A75 Toshiba Satellite P25 Toshiba Tecra A1 .... Toshiba Portege 3500 Tablet PC manual. How to remove and replace the ...
    www.thinkcomputers.org/forum/showthread.php?t=632 - 76k -
    Dec 31, 2008 | Toshiba Satellite A75-S211 Notebook
    Toshiba l45-7423 laptop has two memory slots. With 512 in each, runs ok. With 2 gig in top slot, 512 in bottom slot, runs ok. with 2 gig in bottom slot, says it has memory errors. this limits me to 2.5 gig...
    HI embreelynn,
    just want to check, did you left the top slot open when you put the 2gig in the bottom slot, if you do, I suggest you try it with the 512 in the top slot and the 2gig in the bottom, the reason is that some mobo implements "banking" which means that you'll have to fill in the 1 mem slot before the using 2nd, 3rd and so on.
    hope this helps, regards.
    Jul 12, 2008 | Toshiba Computers & Internet
    Toshiba Satellite A75-S211 Notebook Logo
    255 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
