Question about Dryers
No heat from dryer
Hi, Darren here, I have a Creda TCR2 Dryer, the problem there is no heat coming from the dryer when its in operation is the heating element gone or could it be some other problem. Kind Regards
  • 50 Answers
There are ways to the element disconnect the power, then get to the element from the back of the dryer. disconnect the 2 wires on the element and use a muti meter. find the ohm section on the meter(it will beep when you connect the test leads) . connect the test leads to the element, if the meter does not do anything the element is bad.
Posted on Apr 14, 2009
Cold air from my tumle dryer. I've taken off the back of my Creda TCR2 and the elements look fine - not tested the wiring but was wondering where the thermostats were as I've read that you are...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
Our tumble dryer is not blowing hot air only cold wot could the problem be ? its a creda simplicity condenser dryer - tc 22 cw
heatman101
Aug 24, 2011 | AEG T58840 Dryer Electric
My creda model tcr2 isnt drying my clothes
heatman101
Jul 30, 2011 | Dryers
My creda mode tcr2 isnt drying my clothes anymore
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
My Creda Excel T323vw dryer is only blowing cold air ?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 04, 2010 | Dryers
Creda tumble dryer T632CW is not heating up. Any
SOUNDS LIKE YOU NEED NEW HEATING ELEMENTS.
Oct 18, 2009 | Dryers
Can you supply an instruction manual for a creda simplicity condenser dryer TCR2
Try this website, maybe you will find out what you need.
I hope this helps
Clothes Dryer how-to instructions. Clothes Dryer help.
laundry.manualsonline.com/manuals/device/clothes_dryer.html
Oct 03, 2009 | Dryers
Not heating up
Hi
If your dryer doesn't heat, check these:
Power from the house -- Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element -- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse -- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring -- A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 07, 2009 | Dryers
A Creda condenser dryer TCR2, it went off won't work at all now
There is a lint filter inside the front of the m/c.
A filter at the bottom left of m/c,undo catches to release it, remove it and wash out under running water to thoroghly cleanit.
.Remove water container at top left front , and empty.
Make sure air intake and air out lets are clear, one at front right, and one at rear of m/c.
You can download user instructions.
Goto;;
www.hotpoint.co.uk
Click on (after sales), click on download user instructions, and follow the guide
Plz rate my solution.
Thanks.
Dec 29, 2008 | Creda IWD12 Front Load Washer / Dryer
CREDA TCR2 TUMBLE DRYER
put it in the bin
Sep 12, 2008 | Dryers
Dryers Logo
431 people viewed this question
Top Dryers Experts
