Question about BenQ FP731 17" LCD Monitor
Monitor not working properly
Turn my comp on and all seems ok try turn my monitor on and it just says no signal input and i get nothing what does this mean.also my wireless reciever does not turn on.
    Sergeant:
    Champion:
  • 225 Answers
Please try to check your VGA card & cable connections, or try to connect the monitor to other PC, & if it works, then VGA card of former PC should be replaced. regards
Posted on May 15, 2009
It will not work i switch it on and nothing happens
Remove cable connecting monitor to computer, turn it on. If you see a "NO SIGNAL" note, your monitor is ok and the problem is the graphic card of your computer. If you've recently removed and reconnected the monitor, might be a bent pin of cable input.
If Monitor is dead when you turn it on disconnected, it's defective and you should repair it
Apr 26, 2015 | Computers & Internet
My monitor won't turn on properly. It just cycles power on and off at the opening Dell Screen.
please check proper powersupply & when power is ok then open the monitor & check fuse ,main filter capacitor& bridge diode.
Jul 04, 2013 | Dell ST2210 21" Monitor
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
Not working
it could be possible that the pwr cord might have gone bad. change it .
before doing that try disconnecting the pwr cord from the back of monitor and hold the pwr button for 30 sec. connect the pwr cord properly and then restart the comp. if this does not work then check with other pwr outlet. if this doesnot work then replace the monitor its a problem with the monitor and needs to be replaced// nothing is wrong with the computer//
May 07, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
When I turn on the computer and the monitor, the monitor does not recognize a signal from the computer. I have tried restarting the monitor and the computer, unplugging all cables including the power...
kkjsr00, You must narrow down the faulty component!!! You must prove what is working and what is not working!! Beg, borrow, steal a "known-good" monitor to prove your pc is operating perfectly and will display the WIN-desktop screen on it. If your pc is A-ok then visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ kkjsr00, when strange and weird stuff starts to appear on the screen of "cold-cathode-fluorescent-lamp" back-lit lcd displays the first place I would look at would be the units internal "switch-mode-power-supply/ccfl inverter supply".. No, No, No, unit not going to sleep!!! SMPS/inverter going into SHUTDOWN mode having detected a fault condition with itself or other circuit and is trying to save itself from catastrophic, nonrecoverable failure. e.g. smoke, fire, burn down house, etc. Do some reading in my profile and those of other fixya tech's and you will find more than enough info to help with your problem. Good luck with repair of "flakey" solder joint or bad electrolytic filter capacitor PLAGUE problem. Yes, you sure have a lot of reading to do!! 12fixlouie or old file is louie12fix also try "buddymc" , "budmrtn" profiles for more info.
Apr 26, 2010 | HP w2207 Monitor
Monitor going to sleep
turn off the hibernation mode if it is turned on.
Jun 15, 2009 | Dell Dimension 3000 PC Desktop
No image
This monitor series( HP Compaq WF1907) seem to have a inherent problem with the sleep mode control circuit. You should take this unit into the service center for repair. Hope this helps.
Apr 01, 2009 | HP Compaq WF1907 Monitor
No signal shows on monitor
When a computer beeps on start up there is a crucial input output piece of hardware no working. If you have any experience with computers check to make sure everything is conected right. I inclued a link for support for your computer. Larry
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3390&LINKTEXT=Support%20Solutions
Mar 06, 2009 | Computers & Internet
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
BenQ FP731 17" LCD Monitor Logo
138 people viewed this question
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
