Question about Stanton STR8-30 Turntable
Stanton STR8-30 Hi, i bought this item from ebay, and when i got it the internal wiring that connects to the two output jacks have all come away. There are four white, red, blue and green wires that need to be soldered back onto the jacks. There is also a think black wire that is soldered to the earth output jack,which I suspect is correct. Can anyone help? Thanks Will
  • 515 Answers
How did the internal wiring come out? Was it pulled, does it look like someone attempted to repair it, and didn't do a good job? Unfortunately, you have to open up the unit to see where exactly those wires were removed from. Those are the tonearm wires, which attach to the PCB which distributes the sound to the RCA cables. If those were pulled out from the tonearm, you have to have the entire tonearm replaced (not diy work). If it came loose from the board - VERY ODD that all 5 cables came loose, but it was bought on ebay, so anything is possible - you need to open up the turntable and solder the cables back (easier said than done). Yes, the black wire is the ground. I suggest you take it to a qualified service center for a diagnosis. You might be able to recover the costs from the seller. Hope you didn't leave any feedback as of yet. It might be the only thing you can hold over the seller's head.
Posted on Sep 23, 2007
SOURCE:
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
Stanton STR8-100 Turntable ground wire?
There is no such ground points in the Stanton STR8-100. The main thing you have to check is the RCA cable used. You should a high quality RCA cable suitable for Phono connections. If you use a normal RCA cable then it will produce HUM because if its weak ground shield.
Try with a good quality RCA cable with Good ground shielding.
Ajin
Apr 27, 2012 | Stanton STR8-100 Turntable
Hi! I need two input/output plates for my Kustom floor monitors (KSC10ML). By input/output plate, I mean the unit that has the volume knob plus the two input/ output jacks that is screwed ino the side...
The KSC10ML has NO volume control... only two 1/4 inch jacks. To get a matching "jack cup" you will probably have to go to Kustom. I have searched for the item on the web and only jack cups that seem to come up are for Marshall or ones that use binding posts. I found one blank one but it is 5 by 7 inches... too big for that Kustom cabinet. In a pinch if you don't need it to be recessed, cut metal or ABS plastic plates and drill for two jacks.
Apr 16, 2011 | Kustom KSC10ML PA Monitor
How do i connect external speakers
Hi, Unfortunately it has no audio output jack / connector. But if you want to enabling audio output just tap it on internal speaker wires ( make it parallel or disconnect internal speaker and use your external speaker).
Regards, vote please, Jay
Jan 19, 2011 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
hi,
yes you need an amplifier with or without phono input.
your turntable has three types of output
1.phono output (can connect to the phono input of an amplifier which has a phono input)
2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
there is a selection switch for phono or line level output on the back side
3. and usb( to computer)
Jan 06, 2011 | Stanton T55 USB Turntable
Trying to connect my DISH DVR, GE TV and DVD/VCR Magnadvox Player. The DVD Player doesn't have a coaxial connection that fits the cable wire and my TV only has one RCA (3 jack) cable that is needed for...
In that case you may require an adapter box that allows multiple items to be plugged in to one socket. Ebay stock this sort of item as do electronics Hi Fi outlets, Radio Shack, Maplins etc.
Hope this helps.
Jan 02, 2011 | GE Televison & Video
STANTON C324 NO DISK \r\nTHIS FIX THE PROBLEM AND COST YOU $25 NO LIKE IN STANTON $320 ;) http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290406538324&ssPageName=STRK:MEWNX:IT
You need a new laser or laser mechanism. You can order one online no problem. The part number is: Sony KSS 213Q. make sure there is a Q at the end of it because sony makes a lot of different laser types and the one inside the Stanton C.324 is the Q. Yes the C.324 has Sony guts. You might also want to look into ordering a RF Signal Processor Chip. the part number is: CXA 2581N. Once again make sure the part number ends with a N. This part you might have a little more trouble finding online but it is possible. The laser mechanism you can find on Ebay for about 20$ to 30$ and if you order it from stanton magnetics it will run you about 200$. The signal processor I bought the other day from a Sony parts Dealer in my home town for 20$. Im having an Electronics Repair place do it for very cheap. If you send your stanton c.324 to stanton magnetics you will end up paying more than the turntable is worth brand new unless you have valid warranty still on it.
Hope I could help you with the problem. Cheers.
Jun 15, 2010 | Stanton C314 Tabletop CD and Mp3 Player
TurnTable left channel no signal
Somewhere in the jack or the plug you have a wire broken. You will just have to look for it. If you have a volt ohm meter, this will aid you in finding the broken conductor. When you find the bad connection, you will probably have to solder it back together.
Dec 29, 2009 | Stanton STR8-80 Turntable
No power cable
There is no polarisation on the input lead - It won't hurt the deck if you get it reversed. If you have a shaver lead that fits, that should be fine.
Matt
Apr 16, 2008 | Stanton STR8-60 Turntable
Stanton STR8-30 Turntable Logo
241 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Anthony
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
