Question about Dual XDVD8181 Car Video Player
Dual XDVD710 Car Video Player
I just bought the XDVD710 Car Video Player and it can't see vedio while driving it has a parking brake lock and i heard that there is a code to break it will show video while driving can someone help
  • 12 more comments
  • Anonymous Feb 27, 2008
    can not watch videos while driving
  • dopemn187 Jun 02, 2008
    what is the code to get my dual audio video to play dvd while i drive?
  • dangerdan788 Jun 04, 2008
    I am having the same probelm but another problem as well the part that comes out of the unit with wires the yellow batt wire is messed up and wont go into the spot it needs to. can i buy a new wire part the whole thing? help
  • oooJIGSAWooo Jul 05, 2008
    what is the code for this dvd player? Dual xdvd8181
  • lilmanemoore Jul 29, 2008
    I cant get the dvd player to work while i am driving
  • Anonymous Jul 30, 2008
    how can i watch video while driving? i have a dual xdvd8181
  • seanrobison Aug 14, 2008
    grounded the wire
  • Anonymous Aug 14, 2008
    video playin while driving
  • slickwilly51 Aug 18, 2008
    cd woant go in
  • Anonymous Aug 19, 2008
    I can not see video
  • Anonymous Oct 13, 2008
    i have this problem except for i do not have my remote. what can i do ?
  • al0080 Feb 08, 2009
    cd / dvd wont go in, motor runs just wont grab
  • prototype96 Feb 18, 2009
    i tryed just about everything execpt the way with the remote cause i dnt have the actual dvd remote that came wit it but that blue warning screen wont go off i here the dvd playing but i cant watch it.
  • game35 Apr 07, 2009
    i have a dual xdvd710 dvd plays but cant see the picture need help on what to hook to where
All you have to do for you to be able to play video while driving is... take the yellow wire with blue strip and wrap it with your ground wire and connect the ground wire to a GOOD chasie ground
Posted on Mar 12, 2009
All you should have to do it ground it.. instead of when the parking break goes up it grounds a connection so ur light goes on.. just ground it with ur main black ground.. works perfect..
Posted on Nov 08, 2007
If you go to this website it has 3 methods of bypassing that.
http://forum.ecoustics.com/bbs/messages/4/302701.html
good luck~!
Posted on Feb 18, 2009
The dvd - code method works like a charm!!!!
Posted on May 18, 2008
One of the wires in the back is yellow and black that is the parking brake wire, if you connect that to the ground (black) wire it will work while driving
Posted on Apr 08, 2009
There is a yellow wire in the back of the Cd player that is supost to go the parking brake there is also a other wire that is suppost to go to the parking brake also so that when the brake is ingaged it creatas a circit. wat i did was just put a toggle switch in between the two wires. it also says something in the manual about u put the switch on for 3 seconds then turn it off then back on in order for it to work. read the book tho to makr sure
Posted on Jan 26, 2009
What i did was put the yellow blue (parking break) wire on a toggle switch so it works when you drive
Posted on Dec 18, 2008
What about if you do not have the remote ?
Posted on Oct 13, 2008
The last one worked for me
Posted on Nov 05, 2007
These methods have worked on a variety of Dual DVD systems (mainly XDVD8181, also XDVD710), unsuprisingly, since Dual stated to me that most installations have the same codes. WARNING! It is usually ILLEGAL and most of all UNSAFE to drive while watching video. I only watch video while parked, and I suggest you do the same. This is for demonstration purposes only, if you use these codes, you do so at your own risk. STEP ONE. Ground the E-Brake wire. No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground). 1. FACTORY RESET METHOD (Temporary) (This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.) ** Go to the Menu ** Get to the Settings Menu ** Select to Reset to Factory Settings. Credit: DKA Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost. ---------------- 2. AUDIO CD METHOD (Permanent) ** Insert Audio CD ** Press PLAY ** Press STOP twice on remote ** Enter 26604 on remote ** Press ENTER ** Take out Audio CD and Insert a DVD Credit: Myself via a DUAL Tech ---------------- 3. DVD METHOD (Permanent) ** Insert a DVD ** Let it play until you hear sound ** Press STOP twice on remote ** Enter 26604 ** Press ENTER Credit: Adam P. The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Posted on Oct 01, 2007
Hook up the ground wire for the parking brake to toggle switch
Posted on Sep 29, 2007
Ground the wire.
Posted on Sep 15, 2007
I need help i got one of them dvd players n i got a problem when i hooked up the deck it says to enter a password n i cant play anything
Posted on Aug 10, 2009
2 Suggested Answers
6ya staff
SOURCE:
j_del
Jeremy Dellow
  • 1586 Answers
SOURCE: Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Jul 31, 2008
Try to bypass a emergeny brake pedal switch for a touch sceen dvd player radio. Its a dual model xdvd710
TRY GROUNDING THE WIRE THAT HAS TO BE HOOK TO THE E BRAKE YOU MAY EVEN HAVE TO GET A SWITCH AN ON AND SWITCH THAT MIGHT WORK EVERY DECK IS NOT THE SAME
Feb 19, 2011 | Dual Electronics XDVD710 Car DVD Player
My new radio plays every thing but when i put a dvd it says warning please stop watch vedio player . you can hear the movie but there is no picture
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
Oct 18, 2010 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
How to bypass a dual xdvd710 without the remote
ground the brake wire from the radio to a switch that cut off and on, to the chassis ground you will have to hit the switch every time you want to watch the tv the switch acts like its hook up to the parking brake so when u hit it twice it thinks that the brake is engage
Oct 09, 2009 | Dual XDVD8170 Car DVD Player
Jul 31, 2008 | Dual XDVD8181 Car Video Player
Dual XDVD700
How to get code for xdvd 700
Apr 28, 2008 | Jensen VM9510 Car DVD Player
Dual XDVD710
I need to reset the password from my XDVD710. So I need your help.
THX
Apr 03, 2008 | Dual XDVD8181 Car Video Player
Dual XDVD710
Is there an over ride code that will allow the dvds to play while the vehicle is running? I am in a custom car club and we have many vehicles with Dual in dash dvd players in them... If there is any way you could let me know either way, that would be great....
Mar 23, 2008 | Dual XDVD8181 Car Video Player
Help
just add a valet swich to the ground and the oher to the other end of the brake wire cable
Dec 20, 2007 | Dual XDVD8181 Car Video Player
Dual XDVD8181 Car Video Player Logo
4,842 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
