Question about Kodak EasyShare C743 Digital Camera
Mode dial and shutter button
How does the mode dial and shutter come off? I need to replace them. I have another parts camera.
    Problem Solver:
  • 4 Answers
There are six screws (#0 phillips) on the sides and the bottom that you have to remove, two per side. Open the battery compartment and remove batteries and leave door open. the front should slip off, you might have to use a small flat screw driver to help the sides seperate. now there are three screws that hold the function button together. with the button out you can remove the old shutter button by GENTLY pushing the two little blue tabs to toward the center and into their little holes. be careful that the button doesn't shoot out and watch out for the spring. reassemble in the reverse order.
Posted on May 13, 2009
How doI set up f11 on this camera
Do you mean set the aperture at f/11?
If you want the camera to set the shutter speed for proper exposure, turn the mode dial to the A position for Aperture Priority. Press the +/- button to display the shutter speed and aperture. Press cursor-up/down to change the aperture and the camera will change the shutter speed to give the proper exposure.
If you want to set the shutter speed and aperture yourself, turn the mode dial to M for Manual. Press the +/- button. Press cursor-up/down to set the shutter speed, cursor-left/right to set the aperture.
Full details are in the Shooting Mode section of the manual.
Nov 17, 2013 | Fujifilm FinePix S4250 Black 16MP Digital...
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Jun 29, 2011 | Cameras
Olympus E-300 Evolt when you press the shutter button to take a picture, the shutter rapidly repets for about 9 times
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 27, 2011 | Olympus Cameras
I just purchased a SystemPro Wireless Remote Shutter release for my Nikon D200 camera. How do I set the menu program so the camera and the remote "talk" to one another? Thanks for your help
You need to set the camera's shooting mode to one of the remote modes. Quick-response remote mode fires the shutter when you press the button on the remote. Delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
To choose a shooting mode, press the mode dial lock release and turn the mode dial to the desired setting.
Jan 12, 2011 | Nikon D200 Digital Camera with 18-70mm...
How do you find and use the self-timer setting?
Hello.
Turn the function dial to the drive mode position.
Press the function button in the center of the dial.
Turn the front control dial to select the self-timer drive mode.
Use the rear control dial to to switch between a ten-second and a two-second delay.
Press the shutter-release button partway down or press the function button to set the mode.
When you are ready to take the picture.
Press the shutter button partway down to set the focus and exposure.
Press the shutter button all the way down to start the timer.
Hope this helps.
Feb 16, 2010 | Konica Minolta DiMAGE A1 Digital Camera
What do i do if my camera is taking blurry?
try this steps
-make sure that the mode dial is in AUTO
-half press the shutter button and let the camera do an auto focus thing
-then full press the shutter button
if that does not work reset the unit press MENU > SET UP 2 . RESET this will restore the unit to factory settings and will not erase your pictures
then try this steps again
Jul 01, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
How can I change the exposures, or f-stops on the Nikon N75 35mm camera?
That depends on the exposure mode. In the point&shoot modes the camera sets the exposure.
In P you can turn the command dial to change the exposure.
In S you turn the command dial to set the shutter speed, the camera changes the aperture to suit.
In A you turn the command dial to set the aperture, the camera changes the shutter speed to suit.
In M you turn the command dial to set the shutter speed, you hold down the aperture button and turn the command dial to set the aperture.
If you don't have a manual, get one from http://www.butkus.org/chinon/nikon.htm
Oct 16, 2008 | Nikon Cameras
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
The camera does not take a photo when I press the shutter button. What should I do?
Check the following: * Make sure the battery or batteries have power and are correctly installed. You may need to replace the batteries. * Make sure the power is on. The camera may have turned off automatically to save power. Press the POWER button to turn the camera on. * Make sure the Mode dial is set to the correct mode. The shutter button will operate when it is set to Manual mode, Automatic mode, Continous shooting mode and Video mode. * Check the number in the lower left corner of the Camera’s LCD screen. If the number is 0, the memory card (or internal memory) is full. Copy the photos to a computer and delete them from the camera.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
77 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
