Question about Compaq Presario 5000 PC Desktop
How to open a 5310us computer?
The usb is been pushed in so i guess i need to open the computer to fix it?
  • teumbirgani Apr 14, 2009
    thank u very much
  • 15 Answers
There are several screws on the bottom of the case that you will need to loosen and remove in order to separate the case from the keyboard panel - make sure it is not plugged in when you do this! and also be sure to discharge any static electricity by touching something metal prior to working on anything internal as the components are sensitive. I recommend working at a wood table on wood flooring or another surface that is not carpeted. Good luck!
Posted on Apr 14, 2009
USB Port pushed into the Maxtor Backup - how do I open up to fix it?
Hi, this video should be helpful to you:
Once you have extracted the hard disk from the case you can either try resoldering/replacing the damaged USB connector/port or replace the shell/caddie with another one.
Mar 20, 2014 | Maxtor OneTouch 4 500GB External USB 2.0...
Tip
How to flash your disk [USB]
How To Flash Your Flash Disk
[ USB ] Universal Serial Bus
  • First : Open Your USB Disk ( Like The picture )
  • There are two black Ships , marked with Three codes
  • A code has 6 Numbers , A VID Code and A Pid COde
  • copy all the codes to a bloc-note
  • open this site : http://www.flashboot.ru/iflash.html
  • Write The First Code Second Code and The Third code (Like The Picture)
1) Click Enter
2) The Site Give's You A lot Of Information
3) Choose You usb Disk Data (See The Picture)
4) Download The Flash Application
5) Connect Your usb Disk On The Computer
6) Open The Flash Application
7) It give's a button written on it : << Flash /or/ Preformat >>
8) Push The Button , Wait For A minute
9) Your usb disk Will Be Flashed ;)
Fix-shad0w
Please Rate .
on Jul 07, 2010 | Computers & Internet
I purchased a usb flash driver 2 GB where do I hook it up to on my old computer to transfer data
what make/model computer?
I **** at guessing which computer you have since there have been enumerous ones ever since they debuted but if you want me to guess...
I'll guess that you may or may not have USB ports.
I'll also guess that if you have USB ports, they will be on the front or back of your computer (possibly both).
I can only guess because you haven't provided the information in the first place.
Hope this helps. :D
Apr 15, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have a GE wireless optical mouse that has decided no to work
I had the same problem till I discovered there are two buttons (not just one) you have to push to re-link the mouse and the USB receiver. Plug the little receiver in, push the tiny "connect" circle on the receiver (which is actually a button I guess), then wait for the red light to start blinking. Then press the little link button on the bottom of the mouse.
Jan 18, 2010 | GE Wireless Optical Mini Mouse 3087897985
Boot error shutting down
That only means that the USB port is not updated. It can detect USB devices so all you need to do is to update the drivers of the USB port on your computer or you may try different USB port on your computer.
If you want to update the USB port on your computer you may go to device manger, right click my computer and go to properties then hardware and then device manager. From there you look on the USB device right click and hit update, you may use internet to update the drivers on the device.
If problem still the same thing you may try other's computers USB port and check if it will happen again.
Hope this works!
Jul 07, 2009 | Sony Walkman NWZ-B105F MP3 Player
How to fix the usb that is been pushed in?
Be brave, be bold... you only need a Phillips screwdriver to open the side cover (2 screws). Once you have access to the darkside... I meant INSIDE of the PC it is even easier to put in place the USB connectors.
Apr 14, 2009 | Computers & Internet
Turns on but does not respond to buttons
Try replacing both the AAA batteries and the back-up batteries. This should probably fix the problem. If not, contact the guys over at Texas Instruments for replacement parts if you need them.
Mar 12, 2007 | Texas Instruments TI-83 Plus Calculator
Sony DCR-HC40 xferring still images from memory stick
I' and many others, encountered the same problem. I've searched for a solution, and luckily, I found one that works for me. Hope it'll work for you as well: Go into your windows\inf folder, find the two msdv files ('msdv.inf.1' and 'msdv.pnf.1') and remove the .1 from the filenames. Your camcorder should install fine.
Sep 13, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
Compaq Presario 5000 PC Desktop Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
