Question about Navman Tracker 5500i GPS Receiver
Looking for a wiring schematic for Navman 5500 I Tracker
  • nomish69 Apr 16, 2009
    i want a pin out of the cable for a 5500i
    and i have an older fuel flow sensor for a navman 500i is it compatible?
SOURCE: Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Posted on May 02, 2008
SOURCE: Navman Tracker 5500 Marine Chartplotter
Yes the screen is replaceable, there are four screws holding it to the PCB and a short ribon and a two wire power lead.
Posted on Oct 21, 2008
SOURCE: navman gps tracker 5110i . lost the operation manual
Look Here....
http://www.navmanmarine.net/upload/Marine/Internet_Manuals/5500_5100/5500_5100_eng_web.pdf
Mark
Posted on Dec 17, 2008
SOURCE: i have navman tracker 5500 gps and the gps signal
I HAVE THE SAME PROBLEM.U WILL FIND THE ANTENNA IS BUGGERED.THERE ARE NO SPARE PARTS AVAILABLE FOR THIS MODEL.LESSON; DON'T BUY NAVMAN OR NORTHSTAR.I HAVE ONE OF EACH. NEVER AGAIN!!!
Posted on Jan 18, 2010
SOURCE: Need 5 pin wiring code for Navman Tracker 900 marine device
Dan,
Did you receive the color wiring following order? I ask this because I need the colorcoding as well. If you have please mail me chrisjord4@zeelandnet.nl
Kind regards Chris Jordan Holland
Posted on Aug 02, 2011
Navman Tracker 5500
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Dec 10, 2012 | Navman Tracker 5500i GPS Receiver
I have a navman 5500i tracker ,the zoom isnt coming up far enough to show water depths and hazards by pushing the + - button .is there an easy fix? Thankyou Muzza
Just got the same one and same problem, I also have a 5505i and is only zooms in close when i put in the c-map chip and it zooms close in the chip area only?? now i have a chip for the 5500i and it zoomed in but only on the Texas part of the map, that is the chip it came with, but i live in Canada. Be carefull the c-map max chip for the 5505i is not compatible with the 5500i it needs c-map nt+ chip. 5500 chip is black 5505 is orange
Jan 19, 2010 | Navman Tracker 5500i GPS Receiver
I have navman tracker 5500 gps and the gps signal not working so there is no signel but all the charter is there
Nov 17, 2009 | Navman Tracker 5500i GPS Receiver
Navman 5500 gps backlight dim but set to max
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
solder a new wire to bypass the short.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
May 27, 2009 | Navman Tracker 5500i GPS Receiver
Navman 5505
I found an agent for Navman.
Aug 18, 2008 | Navman Tracker 5500i GPS Receiver
Aug 11, 2008 | Navman Tracker 5500i GPS Receiver
Navman 5500 tracker
Apr 24, 2008 | Navman Tracker 5500i GPS Receiver
I the lost manual
Hi....
I have gone through your problem.Follow this link.
Hope you are searching for the same.
Mar 30, 2008 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500 turns on but locks itself in the entry page
Have the same problem??
Used to take less than a minute to acquire satellites now takes 10-20minutes.
Nov 08, 2007 | Navman Tracker 5500i GPS Receiver
Navman Tracker 5500i GPS Receiver Logo
573 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
