Question about Alpine IVA-D300 6.5" LCD Screen DVD Player
No sound from Subwoofers
I have a iva-d300. i also have aftermarket subwoofers and mids. i have Rockford Fosgate subs and amps and MB quart mids so they r not junk. both on Rockford amplifiers. i have all of the wiring correct and my mids work fine and i have power to my sub amp. i went thru the manual and im positive i have done everything it says to do.but i have no sound at all coming from my subs. im not sure if there is a hidden setting for the subwoofers in the head unit or not???
  • 150 Answers
Did you check the gain level on the amp? Sometimes a bad or loose ground can cause this also. Was it working previosly and it stopped or did it never work at all. Let me know. Hope this helps.
Posted on Sep 14, 2007
SOURCE:
Repair t7512
Hi, Make sure the connection are correct + to+ and - to -.
Also make the same connection to your amp + to + and - to -.
Make sure that your amp can run the subs, wattage and ohms.
Hope that helps.
Jan 21, 2014 | Rockford Fosgate T212D4 Car Subwoofer
Problem with amp, or subwoofer
sound like the amp has internal problems try another sub on it see if it does the same thing
Nov 21, 2012 | Rockford Fosgate Car Audio & Video
What settings to put on Rockford fosgate Prime 250.1? one P1 12 4 Rockford Fosgate speaker, in atrend LSV 12 vented box. With JVC radio that has the sub woof, MID. What is MID and what setting to put it...
Need to know what JVC deck you are referring to so I can give you optimal settings. Mid is the mid-range of frequencies... ones that are sent to your door speakers' woofers, not the sub-woofer. So set that to whatever you feel sounds best, probably low in my opinion. Subwoofer set it as loud as you want, it depends on what kind of music you listen to. If you want your bass to be "boomy" then set it high. If you want it tight and crisp set it low.
Auto adj is auto adjustment for when you turn the sound louder it increases all settings accordingly. I always recommend putting that on 5 so if you ever want to crank it - the whole system gets cranked.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Nov 04, 2010 | Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
No sound coming out of the subwoofer not blown either what could it be?
we need a little more information to help out here...how do you know the sub isnt blown? why type of sub/amp/ radio? any lights on the amp? what color? is the amp powering on?
Nov 24, 2009 | Rockford Fosgate Car Audio & Video
What are the specs,rms ect on my older mb quart psc 216 speakers
Any type of 4 channel amp that will allow the speakers to be hooked up at 4ohm. I would check your local walmart. The brand VR3 are made by Rockford fosgate as well as lighting audio. From what I have heard they are some really good amps at affordable prices. If you are looking to spend some money I would recommend a JL Audio e2150
Oct 28, 2009 | MB Quart Car Audio & Video
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
15 in subs wont trun on
Hello. You can call Sound Repair 321-690-0808 for estimate.
Jan 26, 2009 | Rockford Fosgate (P210D4) Car Subwoofer
Wiring
You may be surprised to learn that even though there is a negative and positive on the sub it usually dont matter all that much because that amp allows you to switch the polarity of its outputs to allow your mids to sound better... anyways on to your question To wire a sub it depends on how many you have, if they are dual or single voice coils, what impediance your amp is stable at. Tell me what type of amp you are hooking this subwoofer up to and how many are being connected. And ill try and give you the best way to connect the sub(s) to your amp.
Mar 25, 2007 | Rockford Fosgate RFP 2418 Car Subwoofer
Alpine IVA-D300 6.5" LCD Screen DVD Player Logo
110 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
