Question about Maytag PAV2300 Top Load Washer
Water won't stop running, won't advance or wash or spin cycle
1st there was a squealing noise everytime the washer came to a haul. Then one day all of the sudden, the water won't stop running and it won't wash, but it would spin in the rinse cycle, now it won't do anything, please advise any help will be greatly appreciate-Maytag PAV2300 performa model
  • stuart1212 May 17, 2009
    My is doing the exact same thing with one addition... it is leaking. I think it is the water level switch not telling the unit is is full.
  • Anonymous Mar 30, 2014
    My washer will not run a full wash cycle. It stops at 50 minutes on the normal cycle. The rinse and spin cycle works fine when I use that setting. I have checked the water lines and screens, all is well there. The water is on also. When I press the buttons to see if there is an error code, I get F20. Please help!
  • 47 Answers
CHECK THE TIMER AND SEE IF YOU CAN FIX IT. THAT IS USUALLY THE FIRST SIGN THAT YOUR WASHER DOESN'T WORK. ON THE OTHER HAND, IT COULD BE ANY NUMBER OF THINGS, BUT CHECK THE TIMER FIRST. IT SHOULDN'T BE THAT HARD TO REPLACE THE TIMER.
RODNEY
Posted on May 15, 2009
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Won't pump out water
Loaded in truck hauled to repair shop.
May 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Won,t drain on rinse cycle
    There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
    Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
    Squealing noise during spin cycle
    The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
    Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
    Maytag PAV2300 Top Load Washer Logo
    228 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
