Question about JVC KD-AVX1 Car DVD Player
DVD just says reading.....
Just put a DVD with MP3s on it and the disc just spins ahd says "Reading". It just keeps spinning and I can eject it?
    Problem Solver:
  • 13 Answers
Too high speed when writing discs. Use no more than 8X. Try 4X. Also, read again the user manual and check the kind of MP3 files this device can read.
Posted on Sep 15, 2007
Player reading invalid disc and disc is not spinning
My dual screen dvd player was reading invalid disc and disc was not spinning. Took player completely apart and white gears had dirt in them. This was preventing the player from spinning. Used dust remover and cleaned the whole inside and now it works great.
on Sep 01, 2008 | Durabrand DUR7 Portable DVD Player
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Hi there, I purchased a Bush lcd/ dvd combi for my daughter 18 months ago.... All of a sudden it is not reading the dvds and automatically ejecting them, any ideas on what the problem is, and how possibly...
There are two possibilities for this fault. The first one is the spinning problem of disc inside it. If loaded disc does not spins, the mechanism will eject it. The reason for this is damaged sled motor. Sled motor is one which spins the disc inside at high speed. It can be replaced. The second reason is of Laser Pickup Unit itsef. If it does not emit laser beam, the main system circuit will recogonise as there is no disc in the tray, and play function is energised, and will eject the tray out. Check for the first one. This is most comon fault with DVD players. OK.
May 30, 2011 | Bush DVD142RC 14 in. TV/DVD Combo
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd does not play
The most common reason for the Laptop not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your DVD, or issues inserting your DVD or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Laptop including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Laptop going again!
Hope this will help...
May 31, 2010 | Dell Inspiron Notebook
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
My xbox wont play any of my discs
there is something wrong with the eye. look it up on youtube and they will help you out
Mar 14, 2009 | Microsoft Xbox 360 Console
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
JVC KD-AVX1 Car DVD Player Logo
239 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
