Question about Coleman Mach III Air Conditioner
Replacement fan motor for coleman mach3..need wiring diagrm
I had a unit that worked fine till the fan blower motor went bad...I have since picked up a new motor but haven't found the diagram for the new motor.
can you display a diagram for this unit?
Thanks.....Stuart
    Guru:
  • 587 Answers
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Jun 16, 2009
I have a coleman presidential electric heater in my mobile home. The heating element works but the blower wont turn on. What could it be?
First check your thermostat.. RED wire(power) should be connected to the GREEN wire(fan).... a Multi- Meter should read 24v if you have power. If there's power going to the FAN(Green) Then your looking at a Bad Blower Motor (AND, OR) A bad Capacitor.
Hopefuly it's just a loose wire or bad capacitor,, the motor isnt cheap..
!!!STAY SAFE!!!!!.. and best of luck to you.....
Nov 25, 2012 | Coleman Heating & Cooling
Coleman mach3 wireing diagram diagram
Hi, Yes, but you need to know which wires do not need to be hooked up...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 16, 2010 | Coleman Mach III Air Conditioner
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
Blower fan stopped working
Your fan may be overheating.
Here are a few things you can check yourself:
- make sure the air filter and the coils are clean
- check all electrical wire connections for tightness. Be sure to shut off the circuit breaker to the unit. Check all connections.
- look for anything out of the ordinary....burnt wires, burnt wire connections, overheated controls, etc.
After doing all these things, if you continue to experience problems, your fan motor could have bearings that are failing or the capacitor (if applicable) could be weak, or you might have a control problem.
I hope you find this information to be very helpful in your quest for truth. ;-) Let me know if you have any further questions.
Mar 16, 2010 | Coleman Mach III Air Conditioner
AC unit wong start unless I spin the blower
you have 2 windings that are in you motor,One winding is the start winding It give the motor its initial boost that gets the fan spinning.The other winding is the run winding and it takes over and keeps the fan running.So it sounds like the motor is bad because the start winding is not giving the boost it needs to start. good luck--Nate
Jul 15, 2009 | Coleman Mach III Air Conditioner
I have a 13,500 btu coleman on our 1989 avion camper. It was making a very loud noise for some time, and vibrating then the motor locked up on it. My husband thinks the blower went out on it. It was...
You should be able to turn the fan motor freely by hand. If there is any resistance or the noise turning it by hand, then the fan motor is definitely bad. Is it a wall thermostat unit or manual controls? Wall thermostat, you can use a jumper wire from the 12+ terminal of the thermostat to the HG terminal and the fan should come on, if not, then the motor is bad.
Jun 24, 2009 | Coleman Mach III Air Conditioner
Coleman A/C-Heat Pump Start and Stop Run Problems
well you have it great job! on the out door unit when it will not shut off disconnect the yellow wire on the stat wires coming from inside if unit stops stat bad if not contactor "points' if they look pitted or buzz change them #1 reason for compressor failure high amp draw thru bad contactor hope this helps aboout 15.00 at hvac store seperate wires with zip ties so dont get mixed up if only one set of points then 30amp single pole 24vac coil contactor
Jun 04, 2009 | Coleman Mach III Air Conditioner
Fan wobbles on coleman MACH3
What is the model number of your current air conditioner? You will usually have to remove the upper shroud, evaporator housing and condenser housing to get all of this out. With that removed, the fan motor should have three or four studs holding it to the plate. Remove the screws from the plate and the whole assembly will lift out.
May 27, 2009 | Coleman Mach III Air Conditioner
Coleman Mach III Air Conditioner Logo
964 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
