Question about Garden
1957 Farmall Cub was running and starting fine. Started most of the time when the engine turned over. I was pulling some dirt and made a couple of passes. After a couple of passes it shut down and would not start back up. What could be wrong for it to be running fine and then not start up again?
  • 218 Answers
Hi..my name is Keith..and i restore tractors..and when they dont run..its usually from the lack of spark or fuel...but its common on the cubs to have rust(trash) in the fuel tank..but both the gas and spark are easy to check..i hope this has helped
Posted on Jun 30, 2009
MY CUB CADET "KOHLER" ENGINE HAS SUDDENLY {RECENTLY) STARTED TO ETHER CHOKING-OUT OR FLOODING OUT. SO I WIND UP SHUTTING OFF OR MONIPULATING THE THROTTLE SO AS TO KEEP IT RUNNING.
problem in the carby
could be water but most likely is dirt in the main jet or needle and seat a carby overhaul is in order
Sep 02, 2017 | Cub Cadet Garden
I have a international Farmall Cub stamp numbers on the plate 23664 1 numbers I find on the motor L-3. 251-3418 can anybody tell me anything about this I have no paperwork with it
There is a specialist forum
Farmall CubView topic - engine block stamp question www.farmallcub.com/phpBB2/viewtopic.php?t=50638 engine block stamp question. ... While I had the head off of my wife's 48 cub, I noticed several stampings in the block and on the pistons. I understand the stampings
and further info.
http://www.farmallcub.com/phpBB2/viewtopic.php?t=19376
and here http://www.bing.com/search?q=Farmall+Cub+stamp+&form=PRHPR1&src=IE11TR&pc=EUPP_HRTS
May 31, 2016 | Cars & Trucks
Backfiring and missing
possible couple of things
low battery voltage by the system not charging enough
overheating component in the ignition system--coil failing when hot
engine overheating- no air flow around head and cylinder fins from dirt and rubbish
May 26, 2017 | Cars & Trucks
I have a 20 hp honda engine on my cub zero turn mower and i can't get enough rpm to run the mower I take the carb apart to look for dirt and can;t find any but when i put the carb back on it runs fine...
Check and make Shure that it is firing on both cylinders
your can pull plug wires one at a time if the engine speed don't change when you pull the plug that side is not working it also could be your fuel shut off cylinder on the bottom of the carb
Sep 23, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Changing the oil
Hi there..my name is Keith and i restore tractors....and to answer your question..a Farmall Cub hold 3 quarts of oil..i hope this has helped
Jun 28, 2009 | Farmall Cub Tractor Radiator
Farmall Cub 1955, runs fine for about 20- minutes
I have cub that done same thing, there was crud in orfice between tank and sediment bulb, cleaned orfice, runs fine.
May 30, 2009 | Farmall Cub Tractor Radiator
Tractor stalls after approx. 15-20 of run time (1957 farmall cub)
try the 12volt coil. and remember the positive verses ground . you might have to order one from whitenys.com search that web site , i hope i spelled it right ,dang it sucks being 50 years old and cant remember things. but any ways check that website out okay .
Nov 26, 2008 | Farmall Toys
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
