Question about Archos 604 Digital Media Player
Archos 604 dvr blank screen
Hi I have set my archos up to my satelite and tv as detailed in the instructions, the problem is i get no picture on the screen of my tv. I get the sound from the sattelite and i can get things already recorded on my archos to play on the tv but i cannot get sattelite picture on either my tv or archos. I have no idea what i have done wrong. Cheers Rick
  • dindy Feb 20, 2008
    I having the same problem, I can view what I have downloaded from my pc on my tv through the archos, but I cannot record from my tv, it is just a blank screen with no sound, Could it be anything to do with the HD tv that I have. I have the HDMI lead from my tv to my cable box via channel 5, but only view archos screen on channel 1 which has no picture because of the HDMI lead being direct to cable, any ideas
  • 26 Answers
It sounds to me like there's an Component A/V cable issue. Please re-check the cable connections making sure they are connected correctly. When using the docking station and Component A/V cables you must be sure the cables are connected with their corresponding colors on the back of the DVR Docking Station. Also check that the format of the recording is compatible with the "TV Standard" in the settings menu of your Archos. It will be either NTSC (USA) or PAL (Europe). Be sure to check the Video Output Settings of the Archos to be sure it is set to the same type of cables you are using- component, RGB, s-video or composite. Good luck!
Posted on Oct 12, 2007
  • Paul Polson
    Paul Polson Nov 24, 2013
    I have the Archos 605, Can I browse into the internet without the plug-in issue.?
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Apr 09, 2010 | Archos 604 Digital Media Player
My archos 604 won't play on my television.
Hi,when you connect it to TV,I believe you switch to AV mode on TV to allow signal to be shown on TV,do you ??.
If you did it but no video ,than make sure your AV cable should go all the way down on the plug on Archos.it is a fancy plug sometimes stays out half way
kazim
Jul 15, 2009 | Archos 604 WiFi Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Same here david! ARCHOS DVR STATION GEN 5 REMOTE NOT WORKING
Hi g tongsonmy name is Mike Houston of DISH Network and I was going over your post and seenwhere your Archos DVR is not working with the remote. If your Archos is sync tothe DISH Network receiver and all the functions still are not working you willneed to call Archos and I will give you the number. Archos (Pocket Dish),8773008879
Jun 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Archos 604 (not WiFi) connection to TV without the DVR station
HI, bought the following off ebay and they worked just fine. I to thought that the socket on the right side was audio only. Can't get a picture via my DVR (may be a fault) however this item works great.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=370172642094
Jun 06, 2008 | Archos 604 WiFi Digital Media Player
How to record from DVR station
hi there, it should be easy, if your wanting to record off the tv/dvd or video you need to plug (lets say your using phono leads,the ends with red,white,yellow on them) into the output on the video (or what ever the device) the on the docking station plug them into input. then on the archos go to the videocorder n away you go. hope this has help`d
Feb 23, 2008 | Archos 604 Digital Media Player
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Archos 604 Digital Media Player Logo
132 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
