Question about Dishwashers
Frigidaire dishwasher model-GLD2445RFC0- PF code came on and then lost power to dishwasher. No power to dishwasher for 3 days now. Outlet is good and has power and circuit breaker is also OK.
  • gilvega01 Apr 14, 2009
    Frigidaire dishwasher Model-GLD2445RFC0- PF code came on and now there is no power to dishwasher at all for a few days now. Power outlet is ok and functioning.
  • 19,396 Answers
PF flashes if the washer loses power during a running cycle.
If you have PF code and machine has power,
just press START to continue the cycle from the moment that power was lost or press STOP/CANCEL to clear the display and completely cancel the cycle.
If instead machine lost power completely , check wiring to control panel, wiring harness from power outlet and test on a different power outlet, eventually using an extension.
If that does not fix the problem, you may need to replace wiring harness or timer control assembly.
Click here to find all diagrams and replacement parts for your appliance.
Posted on Apr 14, 2009
  • Ginko
    Ginko Apr 14, 2009
    If there is no power at all, and it is not the outlet, there is need to read voltages at the control board using a multimeter. Probably there is a lose contact or a short had blown something inside. First part to check is the timer board.
    You need a technician to do that.
  • 6,784 Answers
OK, this code represents a power failure and it could have possibly happened when your breaker experience a hit or surge form the outside line transformer during a electrical Storm or high winds. The surge may have damaged the control board or simply tripped the safety feature. I recommend first trying to reset the board. Unplug the dishwasher for 5 minutes. you can pull the physical plug or turn off the circuit breaker for 5 total minutes. after the 5 min reset, plug or power up the breaker and the dishwasher should start. if it dose not start after the reset, this will confirm the control fault and you may have some major damaged within the power supply board and the control board as well.make sure you clear the error code before you start the 5 minute reset.
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
I need to know what the error code pf means for a frigidaire gallery model #fgh202465nf1a
Hey Carol, I understand that you are receiving an "PF" error message on your Frigidaire Dishwasher. Typically this error code indicates a power failure. Before considering contacting a service provider, I would recommend resetting the dishwasher by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dishwashers
FDB4315LFC2 runs then stops and flashes pf ?
Good Morning Friend,
I understand that your Frigidaire dishwasher, model# FDB4315LFC2, starts and then stops, and flashes a "PF" code when it stops. The "PF" code is stating that there has been a power failure. There could be a possibility that your dishwasher is losing power mid-cycle. I suggest checking your home's circuit breaker, the wiring to your dishwasher, and if you have a cut-off switch, checking that as well. I also suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
What does pf mean when it comes up on my dishwasher model no. fdb2320rec2
POWER FAILURE.. you lost power to the dishwasher either whole house or just dishwasher,,,not sure why we need the dishwasher to tell us that we lost power, but too many can cook the control board,,,did mine. good luck
Mar 18, 2014 | Frigidaire DGBD2432K Dishwasher
Power failure
  • Find the "Start/Cancel" button on the dishwasher's control pad. This button is located on the far-right side of the pad on most Frigidaire Gallery dishwasher models.
  • 3 Press the "Start/Cancel" button to clear the "PF" error code. Resume using the dishwasher as normal. You may have to reselect and start your cycle from the beginning.
Dec 02, 2013 | Frigidaire FDB520RH Builtin Dishwasher
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
My frigidaire dishwasher is blinking lights and a
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jun 24, 2010 | Frigidaire Professional Series 24 in....
Era codes
The PF code means that there is a power problem with your unit. Make sure that you're not having issues with your outlet.  Check the connection at the junction box to make sure they're good and tight.  If both of those check out ok, open the front panel of the dishwasher and check the wiring harness there.  About 1/3 of the way up from the bottom of the door, inspect the wire harness for any signs of cracks or breaks in the wire.  Repair the damaged wires and that should take care of your PF issues.
Jun 24, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
1,048 people viewed this question
Top Dishwashers Experts
