Question about Ovens
I have an old Chef Balmain fan-forced wall oven. It constantly flashes the word 'help' on the screen. Can you advise how to turn off the help sign?
Just reset it and it'll stop flashing the help sign. i am just wondering if you still kept your ovens specifications, if you did, would you be able to help me as to the dimesions of this oven. i have the same oven and it died yesterday. i want to buy a new one and wants the measurement so that the new one that i'm looking for woiuld fit exactly in the old one's spot. thanks,
Posted on May 20, 2009
  • westlau Mar 27, 2011
    can u please tell me what the age of a Balmain oven is...r they fairly reliable??
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
Feb 28, 2011 | Ovens
Old Magic Chef wall oven (model 9875-5XRB), constantly beeps and displays the F1 error code. I have replaced the touch pad once before. Is that the only solution?
Does anyone know the answer? This was posted in October 2010! I ran the self clean too about a week ago. But we had a bunch of power outages last night. Today my oven has taken to beeping and flashing the F1 code. It is almost the same Model number. they wrote 9875XRB (not 5XRB) ...
Oct 18, 2010 | Ovens
Chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Apr 12, 2009 | Ovens
Ovens Logo
583 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
