Question about Hardware & Accessories
Kitchen drawer roller problem
My kitchen drawers were made in 1978. I need to replace the rollers. All I can find are 3/4 in. and above. Do you know were to find 1/2 in. I've gone to Home Depot and searches online but can't find any.
  • Anonymous May 21, 2009
    Need half diameter quarter wide rollers!!!
    Problem Solver:
  • 5 Answers
Phone or online look for custom cabnet shops more than likely have some or can still get from supplyer
Posted on Apr 15, 2009
I want to clean under the bottom drawer...the floor. Do I need to remove the drawer?
No. The refrigerator is a self-contained unit that is not open on the bottom underneath the drawer. You need to slide out the refrigerator (get help if needed) to get beneath it. Depending on the type and age of your refrigerator, it may or may not have roller wheels. AND depending on the type of flooring you have in your kitchen (or wherever the refrigerator is located) will determine how difficult it will be to slide out your refrigerator. Be careful, don't pull too ******* top as this could cause the refrigerator to tip over.
Nov 14, 2017 | Refrigerators
How to change the bracket holding bottom drewer
First i need to know if your drawer is a kitchen drawer or dresser drawer It must be dresser drawer with plastic guide bracket Take your bracket to lowes an match it up place it where you have the old one DO NOT NAIL THE BRACKET USE SCREWS THAT WILL NOT SPLIT THE WOOD kitchen drawers have roller guides
Sep 12, 2017 | Cars & Trucks
Ir2025 drun replace
Might be a problem with your paper pick-up roller from the drawer 1. Clean it or replace it.
You need to remove the drawer and then you can see the roller.
Feb 13, 2014 | Canon Office Equipment & Supplies
How do you remove drawer from chelsea vanity cabinet. It's a single soft close large pot style drawer. It's doesn't seem to unhinge at the end to lift out. It's a Forme Bathroom one
pull the drawer all the way out Lift the up front slightly and lift the drawer rollers over the track rollers in the cabinet. Replacement is to hold the front up while you place the drawer rollers in the track over the track rollers , push in slightly ,lower the front onto the rollers and push all the way in
May 04, 2013 | Furniture
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
I have a set of blum tandem kitchen drawers and no instructions and I need help
The following link, has cabinet and drawer specifications, for the Blum Tandem 562H Series, and Tandem Plus Blumotion kitchen drawers,
http://www2.woodcraft.com/pdf/77B74.pdf
[This is a PDF file download. Give it a few seconds to download after you click on the link.
{Or copy and paste the above link into your address bar, and press the Enter key)
Viewing the setup dimensions for the drawers and cabinet, and where the template goes, may help you.
I need specifics on what help you need. Ask away.
Sep 07, 2009 | Dmm Blum Tandembox Sink Drawer With...
Hp 4000 roller replacement
Sorry, I forgot I posted this. I figured out how to get the rollers off and back on. The problem now is that I replaced the smaller rollers but it is still failing to pick up the paper. It worked well for about 3 days and is back to the same paper jam error, minus the groaning. Any ideas? These would be the intake rollers on trays 1 and 2.
Nov 05, 2008 | HP LaserJet 4000n Printer
Drawer beneath oven keeps falling off it's little wheels
I sympathise with your problem and sorry about your broken toe.. The drawer sits in a slide and the rollers on the drawer travel inside the track.. If your husband is reasonable handy ( or you ) ..empty the drawer and try to get the wheels into the track on the oven.. this process is similar to that used on some kuchen cabinet drawers and furniture so it is no different..just hard to see or get it started..
With the drawer out of the oven..use a flashlight and examine the track to make sure it is not damaged ( do the same thing on the mating slide/rollers of the drawer)..
If possible, can you return to the place you bought it from and have them show you how to do it? They owe you at least that much... Good luck and take care of that toe...
Sep 21, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Freezer Drawer won't open on Kenmore 22" Bottom Freezer Refrigerator
Try raising the door. It may be off the roller tracks inside. If you get it to open you'll find the problem. These tracks are like kitchen drawer tracks.
Jun 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hardware & Accessories Logo
673 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
