Question about Optoma EP732H EZPRO DIGITAL PROJECTOR Multimedia Projector
No signal displayed
I have been using this projector and today all I get ism a blue screen and "NO SIGNAL" ON THE SCREEN?
    Problem Solver:
  • 14 Answers
Try using a new cable and scrolling through the inputs.
Posted on Jan 16, 2010
Why will my mitsubishi lvp x300 projector only project a blue screen when I turn it on?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal.
Sep 06, 2014 | Mitsubishi LVP-X300 Multimedia Projector
Why will my mitsubishi lvp-x300 projector only project a solid, blue screen?
Blue is probably the default "no signal" screen. It means that the projector is getting no signal..
Why does my Mitsubishi hc5500 projector only display a blue screen but still play sound?
The unit may need cleaning. The lamp will shut off if the air flow is blocked by dust.
Aug 31, 2014 | Mitsubishi HC5500 LCD Projector
Blue pixelation spots all over main viewing screen.
Your dlp chip needs replacing. It's a job to do but you can do it.
Jul 23, 2017 | Sony Video Cameras
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
HDMI inputs do not show a picture. They worked but now do not. They display the setup program from the Onkyo AV receiver via HDMI output, but not when the receiver is pushing any other signal via the...
This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Dan
Aug 21, 2010 | Panasonic PT-AX200U Projector
Cannot conect presario V4000 to projector
Set your screen-resolution to 800-by-600 at 60 Hz.
Then, use Fn-F4, to see if the projector accepts 800-by-600 input.
Apr 10, 2010 | Compaq Presario Notebook
TDP-S20
Click the 2 box on the display settings and put a check mark ano the box that is say to extend the view on to this monitor. Hope this Helps.
Jun 17, 2008 | Toshiba TLP S30 Multimedia Projector
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
205 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
