Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Connecting extra monitor.
By essie637 on Apr 14, 2009
Hi I have a new acer aspire x1700, when ordering it it stated that it has pci express slots which I needed for a video card I bought to install in my old pc (which I broke, don't ask!) I thought I'd keep it to install in my new pc as I want two monitors. However the two slots available are taken, one of them has the video card with monitor connection, which i am using now, there is another vga connection on the back which had a cover over it, I have tried to use it but it dosent work, could it be disconnected or diabled? it is not showing on device manger as a video adaptor. Thanks.
Comments:
Apr 14, 2009
- Hi thanks for replying, the second monitor is not showing anywhere, as the connector was capped off i am wondering if it was disconncted from the motherboard because the pc was shipped with a higher spec video card, or if I just need drivers, although I wouldn't know what drivers. this pc came with nothing, no manual or discs, and the acer website dosen't have any info for this model.
Apr 14, 2009
- Thanks Siawolf, What a pain, I was hoping there was a way around that, especially as I recently bought a video card, oh well. Thanks.
Apr 14, 2009
- I am confused now but I am sure there is a solution without buying extra. I have read that I can have two monitors without a dual card.
The pc has two cards one has a DVI and HDMI connection the other has just one normal monitor connection. (no s-video). Lower down there is a HMDI and Monitor connection which came covered with a cap (I presume disabled due to upgrade as explained)
What I would like is two monitors (web designing work) and my pc connected to my TV, (which has HDMI and DVI connections). I also have the spare card I bought before which has a normal monitor connection, a DVI, and s-video connection.
I would like to know if there is much difference between DVI and HDMI? if so which is better.
Could I take out the card which has the DVI and HDMI connector and install my spare videocard with the DVI connection, would this work? and if it did would I be able to enable the HDMI connection which was previously capped off?
Sorry this is long, I appreciate all the help recieved.
Best Solution
posted on Apr 14, 2009
Very Helpful)
siawolf
Rank: Guru
Rating: 85%, 294 votes
the videocard the monitor is connected to is active, this most likely is a upgrade and the onboard (on motherboard/integrated) is automatically DISABLED when you insert any pci-e video card in the expansion slot.
If you want to run two monitors, you need to remove the video card in the expansion slot and replace it with a dual monitor capable card.
these will range from 30 to 500 dollars depending with one you want.
Comments:
Apr 15, 2009
- well, you can use two add-in cards , or one with dual monitor capacity. i havent seen a motherboard with onboard video not disable itself when you plug a video card into the pci-e slot. perhaps you could clarify if you were talking about: onboard video+PCI-e or PCI-e+PCI-e ?
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Very Helpful)
gymowner
Rank: Wiz
Rating: 85%, 233 votes
You have to enable it before you can use it. Right click on the desktop in an empty area, select properties, then settings, then click on the picture of the second monitor, it wil ask you if you want to extend your desktop to inable the secod monitor, the rest I think you can figure out, good luck, if you still have a problem just note it and i'll check back
Comments:
Apr 14, 2009
- it sounds like you only have a single video connector. That is indeed rare these days. does the card that you used in place of the onboard video, a single video head and that's it or is there an s video on it. Also you can pick up an 8800 geForce with 2 heads for 50-100 dollars
Apr 14, 2009
- yes you should be able as long as there is a slot for the card, we used to run multiple monitors by running individual video cards before windows 98, So yes by all means try it
Apr 15, 2009
- The DVI and Hdmi are similar the HDMI is newer, ther are converters that change DVI to HDMI
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
sound card driver  pls help find one
Answer
i have asus p5p800-vm mother Bord 1gb ddr1 ram . and buy a game farcry 2 i don't know witch type of... (More)
Describe your Motherboards problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in Newport, KY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
