How do you install a new belt? its hard to fit around !!
Belt in washing machine broke. can't get new belt back on. how do you install the new belt?
  • 3 Answers
Youmust loosen the motor bracket bolts and this will allow the motor to swing. Put belt on the motor pulley and feed the belt onto the large drum pulley and at the same time turn the drum pulley so that the belt pulls onto the pulley groove. Put some tension on the motor to tension the belt - not too much tension though. Holding the motor & belt tension, tighten the motor bracket bolts - job done. Should take no more than twenty minutes to complete.
Posted on Apr 15, 2009
How do i replace the drive belt
If you tip the washer back, you should be able to see the drive belt on the bottom of the machine. Chances are, the belt broke and didn't just fall off. I would suggest taking the old belt (which you'll find there on the floor) to an appliance store and have them match it up with a new one. Installation is fairly straight forward. It will go around the motor, transmission pulley, the water pump, and a tensioner (if equipped.) I hope this helps! :)
May 01, 2014 | Kenmore 24032\24036 Top Load Washer
Front loader washing machine inside hard plastic bar broke off
there are several kinds of plastic cement..everything from superglue to plastic pipe cement like plumbers use..available at most hardware stores..even model glue..I would try one of these before pitching the washer..you nmay be able to screw it on using stainless steel sheet metal screws also..
Jan 15, 2014 | Kenmore Washing Machines
970-C98802-00
see the video and fix it. God bless you
Jul 18, 2013 | Kenmore HE2 Plus Front Load Washer
I have a GE washer WHDSR316G1WW and I cannot get a new belt installed. How do you install the new belt? It barely fits around the large pulley.
You are correct in that the belt seems overly tight. This is what I did.1) Get the belt on the large pully2) Using several ZIpTies every few inches, secure the belt to the pully3) Get a metal hanger and loop it through the belt making a safe handle at the end.4 Cover the handle with a cloth to protect your hands and to also provide grip.5) Have my 300 lb, 6'7" hulk of a son pull as hard as he can while you assist getting the belt on the motor spindle.
Sep 13, 2011 | General Electric WHDSR316G Top Load Washer
How do I take the back off my wt540? I am trying to replace the belt
unfortunatly the back does not come off this machine, only the small inspection panel at the rear.
belt can be really hard to fit, hotpoint actually supplys its engineers with a specialist tool to fit the belt.
i fit it by removing the lid and inspection panel, fit belt around motor first then from the top feed onto the drum pulley. a tip is you can cable tie the belt to the main puley(use a few) then slowley rotate and belt should slip on, sort of like putting a chain on your bike.
may take a few trys, good luck with it and let me no how you get on.
Jul 06, 2011 | Washing Machines
The belt from an Indesit washing machine broke a wire
The wire you refer to is an earth wire, it has probably pulled of the motor or the frame of the m/c.
If you can't see where it came from, don't worry too much, all you need to do is fasten it to a metal part of the m/c so that is is making a contact to earth.
I assume that you can get a belt o/k
Make sure that the drum and motor are free before you fit new belt.
Plz rate my solution
Thanks.
Dec 23, 2008 | Indesit Washing Machines
How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
May 20, 2008 | Samsung WF337AA Front Load Washer
How do I fit a new belt on my Indesit Wil 113 washing machine?
I think its a 'front Loader'? Take the back panel off, to expose the main drive belt & pulley. When fitting the new belt it needs stretching by first putting it around the motor drive shaft & easing on to the main pulley whilst gradually rotatng the pulley. You need to finish up with the belt in the centre of both of the pulleys if possible
Oct 31, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
1,076 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
