Question about Jack Lalanne Power Juicer 250 Watts
Repair or replacement of Power juicer
The top of the plastic housing cover that the blade screws on to broke. I only had it a couple of years when this happened. I've been trying to find out how to get it repaired. It didn't get used enough for it to have simply broken. The machine has not been dropped. How can I get this repaired or replaced. It is a usless piece of equipment since the blade cannot be attatched. It was a lot of money to spend on something that did not perform up to my expectations. I have a "bad taste in my mouth" each time I see an informercial or see these juicers being promoted on shopping networks. Is there not an actual person I can speak to regarding this useless juicer?
  • 5 more comments
  • Rsdp Nov 17, 2007
  • quilly Nov 21, 2007
    plastic housing that screws into blades has broken - only about a year old.
  • jsr2000 Dec 26, 2007
    Same problem. Male screw that attaches to blade deteriorated. Can't fine a way to repair it.
  • Jock50 Aug 02, 2008
    Had exactly the same problem and was told that you have to buy a completely new juicer in UK as no parts are stocked here.
    Also was told that this problem is not unique and is a design fault in all the JLL juicers and are not covered under US warrantys.
    have now bought another juicer but not a JLL due to this common fault.
    Jock
  • Anonymous Aug 03, 2008
    yes same problem.
  • Anonymous Aug 14, 2008
    Same problem. Had it for 3 years. The website for Jack LaLanne's juicer website had a number and we are having the part sent to us! The part has a lifetime warranty, but shipping was about $26. Call 1-973-287-5150 and provide your model number.
  • robertgarmon Aug 20, 2008
    Went to use the juicer and the plastic piece ocer the motor that the blade screws onto brock.About 1/4 of it brock off. This juicer is only about 1 1/2 years old and is not used that much for this to happen. It is also always stored in the box with the packing around it. I like this juicer but if this is going to be a big ordeal I will never have another.
The part has a lifetime warranty. Just call the customer care line at 1-973-287-5150 and give them your model number. You have to pay shipping though. Our shipping cost was about $26.
Posted on Aug 14, 2008
The link is no good anymore, can someone provide an updated link to order replacement parts.
Thank you.
Posted on Jul 27, 2008
  • soi812 Jul 27, 2008
    Here's the new link to the main page, there is a link to parts here.
    http://www.powerjuicer.com/index-classic...
  • 4 Answers
SOURCE:
How do I remove top plastic round part from the rotor of the motor?
The manufacturer warrants that your Jack LaLanne Power Juicer is free of defects in materials and workmanship and will, at its option, repair or replace any defective juicer that is returned. The Jack LaLanne Power Juicer's motor is warranted for the lifetime of the original purchaser, and all other parts and components are warranted for 60 days from the original date of purchase. This warranty is valid only in accordance with the conditions set forth below:
1. Normal wear and tear are not covered by this warranty. This warranty applies to consumer use only, and is void when the product is used in a commercial or institutional setting.
2. The warranty extends only to the original consumer purchaser and is not transferable. In addition, proof of purchase must be demonstrated. This warranty is void if the product has been subject to accident, misuse, abuse, improper maintenance or repair, or unauthorized modification.
3. This limited warranty is the only written or express warranty given by the manufacturer. Any implied warranty of merchantability or fitness for a particular purpose on this product is limited in duration to the duration of this warranty. Some states do not allow limitations on how long an implied warranty lasts, so the above limitation may not apply to you.
4. Repair or replacement of the product (or, if repair or replacement is not feasible, a refund of the purchase price) is the exclusive remedy of the consumer under this warranty. The manufacturer shall not be liable for any incidental or consequential damages for breach of this warranty or any implied warranty on this product. Some states do not allow the exclusion or limitation of incidental or consequential damages, so the above limitation or exclusion may not apply to you.
5. This warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
If you want to order or have questions about specific parts or accessories, feel free to call us at our customer care department:
Phone: 1 (973) 287-5150
Procedure for Warranty Repairs or Replacement
If warranty service is necessary, the original purchaser must pack the product securely and send it postage paid with a description of the defect, proof of purchase, and a check or money order for $29.99 to cover return postage and handling to the following address:
Tristar Products, 500 Returns Road, Wallingford, CT 06495.
Sep 27, 2014 | Jack Lalanne Power Juicer 250 Watts
The plastic screw, which the grater is screwed onto (looks like part of the motor) is broken.
I had the juicer for exactly two weeks and the same piece broke. The little plastic part in which the blade screws onto. Called the company and they were actually no help at all. Please don't waste your money!
Nov 14, 2009 | Jack Lalanne Power Juicer 250 Watts
The blade keeps rubbing with the upper part of the machine
Make sure the orange blade is properly seated and screwed in place. Don't screw it too tight though. If it still touches the top cover, sand it off or file it off. Whatever the blade touches the white portion of the cover, file it off.
Oct 28, 2009 | Jack Lalanne Power Juicer 250 Watts
I HAVE A JUICER MODEL #JE95XL ITS ONE YEAR OLD,I
Go to Lowes, to the cabinet knob dept. Get a cabinet knob that matchs the holes in blade. You can always bend the screw a tiny bit if needed to fit. Put the screws into cabinet knob, and tighten. Cut the heads off and you are ready to go. They have a knob that is stainless steel, just a flat piece across the top, an 2 straight pieces that go down. I think it was $2.97. It gives good grip, and takes the blade right off.
Aug 21, 2009 | Breville JE95XL Juicer
HOW DO YOU take apart the jack Lalanne juicer blade and top unit to clean
LIFT UP AND SLIDE COVER RETAINING BRACKET OFF COVER, REMOVE COVER AND
PLASTIC NUT THAT HOLDS DOWN BLADE. ALL PIECES JUST LIFT OUT, BUT KEEP TRACK
OF THE ORDER THEY ARE REMOVED IN TO REINSTALL CORRECTLY.
Jun 28, 2009 | Jack Lalanne Power Juicer 250 Watts
The little thing you screw the blade on to broke off, where tdo I get that fixed
i believe you would have to send it back to the manufacturer for repair or replacement
Jun 16, 2009 | Jack Lalanne Power Juicer (Stainless...
Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Jan 25, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Trying to find a part for the power juicer CL-003 AP
The top white part connects to the motor. You have to buy the whole bottom part. It's not separate.
Jan 09, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Juicer
There is the metal thingy that slides up over the upper unit.  Pull it towards your firmly.  Once it's down you can lift off the top housing.  Then you'll see the blade.  You need that little orange crescent tool to fit into the two holes in the blade.  Turning it will loosen.  Then the blade screws off (righty tighty, lefty loosey).  It's just a matter of taking off the parts then and washing them.  The screen thingy is easiest to wash from the outside with a nice scubby pad.  Reassembles same way.
Sep 12, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanna Power Juicer
Visit www.powerjuicer.com and find a replacement part.
Aug 04, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
1,141 people viewed this question
Top Jack Lalanne Juicers Experts
Roger Paull III
Andrew Taylor
Andrew Taylor
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
