Question about Echo Pb - 413t Backpack Blower
Need to replace fuel filter
Were is the fuel filter on a echo backpack leaf blower and how do you replace it ?
  • pbconyngham Jun 13, 2014
    Ethylene in modern gas eats up these fuel lines, go to a small motor repair shop and buy a pirece of resitant fuel line(it is yellow)
Fuel filter is located inside the fuel tank. You have to make a hook out of about 10" of stiff wire (wire coat hanger works perfect) Hook end should be about 1/2" wide. Remove the fuel cap, insert the wire hook and snag the fuel supply tube with the filter attached to the end. Pull it back through the fuel filler opening, replace the filter and reinsert.
Posted on Apr 15, 2009
  • ShagNasty Aug 27, 2012
    Problem is the fuel line - rotted, guess need to drain next winter. Need to replace fuel line, Sears does not list a replacement kit. I need to know a replacement part number...
It's in the fues tank It just pops off and you pop the new one in
Posted on Sep 23, 2009
I have a echo pb755h backpack blower that has excessive oil in the air cleaner
Your main jets check valve may be damaged or crudded up so that the minor backflow from the engine pushed fuel out the carb into the air filter. The gasoline part evaporates and leaves the oil behind. Hence the oily air filter. This condition might be remedied by using a fuel system cleaner or it may need to have carb service. If the carb is a cheap enough unit you may consider just getting a replacement if the backpack was a decent high dollar unit.
Be safe and good luck!
Nov 27, 2014 | Echo Garden
Echo 770t misfiring
I have installed new carb kit, fuel lines, plug, and air filter. Blower continues to bogg down when opening up throttle. echo 770 blower any ideas?
Aug 13, 2013 | Echo Backpack Blower PB-770T
White smoke pb265 back pack blower echo
White smoke means water. Change fuel filter and clean tank.
Feb 15, 2012 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Engine stalls immediately when put into high speed
Fuel starvation or 'lean' fuel condition
check and or clean fuel filter
check condition of fuel lines
carburetor diaphragms/gaskets need to be replaced
spray carb cleaner thru jets and ports while appart
Nov 08, 2009 | Echo Inc. 25.4 CC Backpack Blower
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Apr 04, 2009 | Echo Garden
Echo Pb - 413t Backpack Blower Logo
825 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
