Hi there! I've got a problem. I have a Cajun p333t and it reset itself again and again. I doesnt let me configure it... Do you have any idea of what is happening?
What's the model number and what's the part you need? If you're not sure what the part's called, check here:
https://www.manualslib.com/manual/733139/Cajun-Injector-Electric-Smoker.html?page=4
Jul 18, 2011 - 13 posts - 11 authors
... for cajun boats and also a complete manual in pdf format and wiring schematics. ...bassmannbama is offline ... a wiring diagram too because switches arent working andmy wiring ... My email is : [email protected].
Apr 19, 2012 - 4 posts - 4 authors
I scanned in my owner's manual and have it available if anyone is ... Mine is a '95 1950 Fish n Ski, but I believe it would cover bass boats as well. ... Looks like I'll need to learn about electrical and general boat repair.
Hi. Try this: reboot your computer and press F8. choose "last known good configuration". if this doesnt work, try again and choose safemode with networking. once the computer's in safe mode, try doing a system restore. :-)
Use a console cable with following minimum pinout (the flat gray one with the RJ45- D9 type converter currently shipping with new P33xx switches will suffice): DB9 Console Port 1 ----------- 6 2 ----------- 3 3 ----------- 2 4 ----------- 4 5 ----------- 5 6 7 ----------- 8 8 ----------- 7 9
Obviously the speed is set to 9600
maybe stop all sessions & try to re-establish a new one. The instruction manual warns u can only run one..
This is from the Cajun P333R manual but it should be very similar if not identical.
Good Luck.
arp timeout Command
Use the arp timeout command to configure the amount of time that an entry
remains in the ARP cache. To restore the default value, 14400, use the no form of
this command.
The syntax for this command is: arp timeout <seconds>
The syntax for the no form of this command is: no arp timeout <seconds>
Examples:
To set the arp timeout to one hour:
Router(configure)# arp timeout 3600
To restore the default arp timeout:
Router(configure)# no arp timeout
ip-address IP address, in dotted decimal format, of the station
hardware-address 48-bit address of the local data link
seconds The amount of time, in seconds, that an entry
remains in the arp cache.
After changing all the necessary parameters using the CLI, use the write
command to save your system configuration. If you receive any error messages,
your configuration has not been saved. You must correct the errors and re-issue the
write command.
Notification of write errors is presented in a two column display:
? The left column contains the parameter values that you set in this session and
need to be changed.
? The right column contains the parameter values currently saved in the
Cajun P116.
Wait 15 seconds for confirmation of the write process. Then exit Privileged level by
typing exit at the prompt. For example, CajunP116-priv# exit.
The cursor changes to CajunP116> to indicate that you are in Normal level.
Verify that all the parameters were accurately saved by using the show all or
show all list command.
The Cajun P116 is now ready for cabling and operation. You may exit your CLI
session.
Hey Eric, I do use same Avaya switch at my lab at office. To me what you have to do is quite simple, first of all you have to get from your network administrator the following info:
- Free IP to assign to the switch
- Subnet
- Gateway
(If you ping such IP from a machine of same subnet, there will not be an answer).
Then log as superuser (#) and do this:
1. Type set interface inband
Replacing , and with the VLAN, IP address and netmask provided by your network administrator and press Enter.
(for VLAN you can list them and decide which one to use, but normally you should use 1)
2. Type reset and press Enter to reset the stack.
3. After the Reset, perform login again as superuser.
4. Type set ip route , replacing and with the destination and gateway IP addresses. (If you want all packets not from your subnet to be send to the gateway, then use 0.0.0.0 as destination, list routes set on device for more info)
5. Press Enter to save the destination and gateway IP addresses.
That's all. Your switch will be rechable from your same subnet and from other networks if your gateway is working properly and there's no other element blocking you the access.
Good Luck!
