Question about Canon PIXMA MX850 multifunction InkJet Printer
Canon Pixma MX850 says it's out of paper when there is paper
On my Canon Pixma MX850, it printed a couple of pages and then said there was no paper. There was plenty of paper. It said if that was the case, to press the feed switch. I did that and nothing happens. The switch appears to be a dud. Turning off the machine, restarting, etc. does nothing. I can't print anything because no matter how much paper there is in the machine, it says there's no paper. Frankly, I've found this machine in general to be a huge disappointment. I would not recommend it to anyone.
    Problem Solver:
  • 5 Answers
The feed switch changes the paper feed from rear feed to tray feed (paper tray is under the output bin). If you have paper in the rear feed, the green light should be on top of the printer icon left of the feed switch. If you have paper in the tray, the light should be on the bottom of the printer icon.
Posted on Apr 14, 2009
How do I free stuck print head on Canon Pixma MX850
its not stuck its jammed due to some paper or some thing like that kindly remove the cartridge and check any piece of paper .
Jan 20, 2015 | Canon PIXMA MX850 multifunction InkJet...
Canon mx850 Error code 6A00
Hello thank you for using FixYa.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MX850 Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly,where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you will find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
For Further assistance, I am here to help.
Thanks and Keep exploring FixYa
Mar 25, 2011 | Canon PIXMA MX850 Multifunction Printer
I have a Canon MX850 and when I print something landscape there is a line down one side of the page....how can I fix this. The line is in the actual image.
Does the line actually look like many little dots? If this is what I think it might be, then it is just the way it is. The machine has little spiked wheels in the paper path to reduce the amount of contact it has with the media, these spiked wheels can get dirty and start having ink stick to them and cause lines. See if you can see the wheels from where the paper comes out and try cleaning them with water dampened Q-tips.
Apr 02, 2010 | Canon PIXMA MX850 multifunction InkJet...
I can't figure out how to get my Canon PIXMA MX 850 printer to print the last page first and the first page last so that the pages are in order.
In the printing Preferences dialog box, go to the Page Setup tab, and near the bottom you will see an option "Print from Last Page". Put a check mark in this box.
Dec 29, 2009 | Canon PIXMA MX850 multifunction InkJet...
Blank pages from Canon MX850 scanner
Try Removing the printhead of your printer and putit back, and do the clean nozzles and printhead alignment.
Oct 02, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MX850 - paper feed
Look carefully because it is a cassette on the bottom of your canon mx850... so the solution is: or you fill that cassette or you switch your canon (it is a button for that) to take the paper from the top...
Jul 27, 2009 | Canon PIXMA MX850 Multifunction Printer
Pixma MX850
I was working on the Pixma mx850 for 3 weeks now. I have found that you need to reset the using back to factory default. On the display look for the "printer head" cleaning and alignment. Go through the steps that it gives you for printer head cleaning. Print a test page. have you tried to copy in "black/whte" and not color? that will use the large black and not the small black cartrdge. Try a couple of black circles in "paint" if your running windows XP. make a test page of your own and print it.
Apr 15, 2009 | Canon PIXMA MX850 Multifunction Printer
Duplex printing flips page
That should be a setting somewhere in the printer or the print driver on the computer.
Here's a link to the manuals that comes with it.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=16279#DownloadDetailAct
Apr 06, 2009 | Canon PIXMA MX850 multifunction InkJet...
Black line
Try wiping the light bar where the page goes in with your finger.
Mar 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon PIXMA MX850 multifunction InkJet Printer Logo
1,217 people viewed this question
old marine
old marine
