Question about Logitech Extreme 3D Pro Joystick
Logitech extreme pro 3d works fine w/ IL-2 :1946. It will not work with fs 2000, even though w/in fs 2000 "options>controls>calibrate" registers and calibrates this joystick. fs2000 thus recognizes BUT will not be controlled by the j-stick.suggestions? My OS is Vista 64 bit.
  • 16 Answers
SOURCE: 3d pro joystick
There is now.
Visit: http://www.logitech.com/index.cfm/441/291&cl=us,en to download the driver.
Posted on Dec 16, 2007
IrishDruid
  • 2712 Answers
SOURCE: Logitech attack 3 joystick-does it work with my IL-2 Sturmovik game?
First, check your game documentation to see if your game supports the use of a joystick. Most First Person Shoot 'em Ups do not support joysticks, and only supports mice/gamepads.
If joysticks are supported in your game, please read on...
Make sure that your joystick is properly installed and detected by your computer. You can check in Device Manager or Control Panel > Game Controllers. Also make sure you have the latest software (LGS/WingMan) installed.
Next, you will have to create a new profile for your game in the WingMan Profiler:
  1. Open the Logitech Profiler™ by clicking "Start", "Programs", "Logitech", and then "Launch Logitech Gaming Software".
  2. Click "Profile" from the pull down menus.
  3. Select "New..."
  4. Type in the name of the game the profile is being created for.
  5. In the next field, type the path to the game's executable file. It the exact path is not known, use the "Browse" button.
  6. Select an icon for this game profile and click "OK"
A profile for the game has now been created; however, game commands must also be entered. For information on how to do this, please see Knowledege Base article 274.
Hope that helps.
Please dont forget a FixYa rating if this solution was helpful. Thanks in advance.
Posted on May 25, 2008
  • 6 Answers
SOURCE: saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Posted on Oct 20, 2008
abain9608
  • 28 Answers
SOURCE: IL-2 1946 won't even install
I'm not an expert on this game but it appears to be a compatibility issue. The guys in this forum seemed to have worked out a solution. Good luck. http://forums.ubi.com/eve/forums/a/tpc/f/49310655/m/1301002008
Posted on Jan 17, 2010
SOURCE: I need calibration software for the logitec 3d pro
this was not originaly my post but i saved it.and it worked for me. HOW TO CALIBRATE THE LOGITECH EXTREME 3D PRO JOYSTICK
I just figured out how to calibrate this joystick. I am using Windows XP. I assume it will work with all Windows operarting systems though.
Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, THEN click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together. IMPORTANT - Click on the "Test" tab first. If you go to the settings tab first, it likely will not work. Without doing anything else after clicking on the "Test" tab, next click on the "Settings" tab. Then click on the "Calibrate" button below. Click "next". Click the thumb button on the left side of the joystick which should bring you to another screen. Then follow the prompts......
* On the "axis calibration", move your joystick in full circles, making sure the "+" symbol moves around the far margins of the square. After a few complete circles, click the "next" button with your mouse.
* On the next screen, click the left button on the joystick again, which should bring you to the next screen. Move the throttle lever back and forth a few times. Then click "next" again.
* On the "Z rotation screen", move the joystick to the left and right (rotate it) a few times. Then click "next" and then "finish" then "ok". Thats it. It should be calibrated now. Hope this helps everyone with problems.
Posted on Jul 08, 2010
Logitech say the EXtreme 3D PRO WON'T work on my MAC, HELP !!
Well... I was wondering how to make it work on our Mac. So I downloaded the free version of X-Plane 10 off the internet, and I was not sure that the joystick would work. But when I got on the game, I plugged the joystick into the back of our computer and the game said that a joystick has been found. So I clicked on calibrate joystick and then it worked right then. But it is hard to program the joystick buttons too the different commands for the game. Hope this helps. :)
Nov 17, 2011 | Logitech Extreme 3D Pro Joystick
Problems with turning
You need to do a calibration on the joystick. I don't know what operating system you have, but if it a PC, and you have Windows XP you can go into control panel and look under Game Controllers, it should list your joystick. Click Properties and then select the Settings Tab to calibrate your joystick.
Hope this helps.
Jul 20, 2010 | Logitech Extreme 3D Pro Joystick
I need calibration software for the logitec 3d pro joystick. will not maintain level flight in AP (flight sim ).
Feb 08, 2010 | Logitech Extreme 3D Pro Joystick
Joy stick will only work on the left side .when you try the right side it will not work
Have you run it through its built in calibration utility. If not it is available through the control panel>game controls> calibrate
Or the games you play may have a calibration utility in the options menu.
Aug 27, 2009 | Logitech Wingman Extreme 3D Pro Twist...
Too senitive can't control fx9 or fsx
First try the usual suspects. Uninstall *all* game controller software, reboot and install the latest Logitech drivers for your stick. Make sure you've got the latest Vista SP1 + updates. Make sure you're running the latest update of DirectX. Check for patches for your game. Plug the stick into a different port.
Check the physical movement of the stick - any springs feel broken/missing? Tension settings too high or too low? If all those are done, go in to the game controller calibration in Windows and calibrate. Test it - does the stick control the cursor properly? If so, but in-game you have problems, the problem is most likely related to the game code and unless they've released a fix, there's not much you can do.
If the stick has problems with calibration and you've installed any/all updates - likely a defective stick, contact your seller.
Luck!
Apr 22, 2009 | Logitech Wingman Extreme 3D Pro Twist...
Wingman extreme digital 3D Logitech not working on XP
Well you can try download lgs501.exe and run it. This scans on Logitech drivers on your system and can even update them.
( Not checked though, cause I am running on Vista )
Jan 09, 2009 | Logitech WingMan Extreme Digital 3D...
Unplugged my Extreme 3d Pro/When plugged back in, can't calibrate
have you choosen to use the stick in the game controlls options in your games? if not you just choose using joy-stick and customize the buttons and Y-X-axis to what you preffer
Dec 31, 2008 | Logitech EXTREME 3D PRO TWIST HANDLE...
Logitech Extreme 3d Pro Calibration problems.
Hello There,
Also dont' I meant NO, Do NOT install the software that came with the joystick, it lure a lot problems on calibating and others.
use the game control panel on windows instead.
good Luck
Nov 07, 2008 | Logitech EXTREME 3D PRO TWIST HANDLE...
if you havent already try this
Jun 16, 2008 | Logitech Extreme 3D Pro Joystick
Logitech Extreme 3D Pro Joystick Logo
506 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Lyle Siemens
Lyle Siemens
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
