Question about Samsung PCL5415RB 54" Rear Projection Television
Samsung PCL5415RC Chirping noise
My Samsung TV has started making a high-pitched chirping noise when it's been on for more than 30 minutes or so. It sounds like a CD is skipping. When I unplug the TV, the chirping noise stops after 5-7 minutes. This particular model does not have a color wheel, what else could cause this sound? Picture and sound appear to be fine. Thanks, Karen
    Sergeant:
    Champion:
  • 375 Answers
Power supply discharging.even after the set is unpluged.
Posted on Sep 13, 2007
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Making a chirping noise while driving
Most chirping noises are due to bad pulleys on the motor. It's usuually an idler pulley or belt tensioner pulley. May also be the bearing in the alternator. Use a stethescope to check otherwise you can use a rubber hose. Put hose up to one ear and put other end by each pulley. Should hear high pitch chirping.
Jan 19, 2013 | 2010 Jeep Liberty
CHIRPING SAMSUNG PROJECTION TV
Chirping is set is in shutdown---most likely in High voltage area of set.
Jun 11, 2012 | Samsung Televison & Video
Blinking green light in front, high pitched chirping noise, no picture.
u may have a high voltage problem , 1 may be the flyback transformer , or may be u vertical circuit , need to take it to do tv shop for service
May 08, 2009 | Televison & Video
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
On off button blinking.
If your set is making a high pitch sound or chirping sound you can get a repair kit from www.TvRepairKits.com.
It will fix the no audio + no video + set makes chirping or high pitch sound.
Dec 27, 2008 | Philips 43PP9202 43" Rear Projection...
RCA 31" TV pakes high pitched chirping noise
Did you check the Horizontal Output transistor to see if it were shorted, and also check the MOSFET of the switching power supply.
Jul 25, 2008 | Televison & Video
Samsung PCL542R Chirping noise
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
Samsung PCL5415RB 54" Rear Projection Television Logo
538 people viewed this question
Jerry Greenberg
Jerry Greenberg
