Question about Gigabyte GA-M59SLI-S5 Motherboard
Computer Shut Down with no warning
I replaced one 700W power supply when the 4pin cpu power connector from power supply started to get hot and actually became discolored. I learned this after my system, which had been working fine for many months, just shut off with no warning. I replaced the power supply which seemed to correct the problem for a while. Now the system works for a while (one to two hours) and then shuts off. I fiddle with the 4pin connector from power supply a little and the computer boots up and I am good to go for another little while. My cpu is an AMD athlon XP 6000 (125 watts). Any suggestions/ideas?
Thanks so much for your time.
Mike
  • mike_conner Apr 15, 2009
    Thanks for the quick response.
    I was reviewing GA-M59SLI-S5 comments on NewEgg and came across a person who experienced a similar problem. Another visitor to the site, familiar with this motherboard, recommended that he remove the plastic cap on the motherboard cpu power recepticle (making it an 8 pin instead of four) and connect an 8 pin power cable. I tried this last evening and used the computer for four hours with no problem. Hopefully, this will solved the problem. We shall see.
    Scholar:
  • 145 Answers
If you still seem to be having issues - you should try downloading Everst
http://majorgeeks.com/download4181.html
and check the temp of your pc- normally intermittent shutting down is an overheating issue.
Hope everything is staying up and running for you :)
Posted on Apr 15, 2009
  • 13,433 Answers
If your power supply has another set of 4 pins, try them on it. I suppose you have it connected the right way and all, I would consider replacing the motherboard, is this one covered by warranty I'm pretty sure they will replace it under the circumstances.
Posted on Apr 14, 2009
  • Ekse Apr 15, 2009
    Let us know how it goes.
    Thanks,
    Ekse
Desktop shut down in few seconds after getting display
Good day,
The problem you describe is probably due to a faulty power supply.
The four pin connector which you unplugged supplies power to the CPU, which means you will not be able to get a display with it plugged out, as there will be no power to your CPU.
The fact that the PC does not shut down when removing the 4 pin connector strengthens the evidence that your power supply is faulty. By removing the 4 pin connector you are reducing the power required from the power supply to the point where it is not 'overloaded' enough to switch off.
You can test this by plugging in the 4 pin CPU power connector, then unplugging something else, such as the DVD writer.
Then switch on your PC and see if it still shuts down.
If it remains on then the cause of your problem is definitely the power supply.
Replace the power supply and make sure it has a wattage rating of 400 watts or more. These power supplies are relatively cheap, and should be available at your local PC store for about $15.
Best wishes,
Graeme.
Apr 30, 2013 | Computers & Internet
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
CPU fan not working computer shuts down. Replaced fan and it still does this? Hp Pavilion 9597c
Its possible that the Motherboard connector for the fan is not putting out power. there are CPU fans that use a standard 4pin Molex connector, that is what I would suggest you use.
Mar 18, 2011 | HP Pavilion (F2111-60950) CPU Heatsink &...
Let me start at the specs. Asus P5N- deluxe motherboard. Intel Pentium D 940 nVidea 9800 GTX PSU..originally OCZ stealthXtreme 700w and replaced with OCZ Fatal1ty 700W. Western Digital 1 TB...
Hi Tom,
Usually if a PC just suddenly shuts down after a few minutes/hours it is one of two things:
1] The CPU overheating - This is the most common problem. Usually there is no warning and it will just switch off.
2] Motherboard problem (Usually a faulty capacitor on the motherboard) If your machine has been running quite hot for some time - or it is an old motherboard - you will find that some of the capacitors on the motherboard will start to swell up. this is what they look like: http://www.capacitorlab.com/capacitor-types-electrolytic/radial-capacitor-polarity.jpg You will see what looks like a "K" marking on the back of the CAP - the ones in the picture is fine but these ones : http://monkey.org/~blandoon/gfx/caps/cap7.jpg are what they look like when they are swollen. If your caps look like this - it means the motherboard overheated at some stage (or is quite old) and this will also cause a machine to suddenly turn off.
If you have a similar CPU, from a friend or something - you should try swapping that first and test - if it still happens - it could be the motherboard.
this is not a software error as the machine would not turn on after it switched off so that is not caused by a virus or a software problem.
Hope this helps
Good Luck
Feb 04, 2011 | ASUS P5NT Deluxe Motherboard and Intel...
I am installing a new power supply. Need wiring diagram to make sure all components are hooked up properly.
Basically each connector is made so that it can only go where it should go unless you do some modification or really force the connector in.
All in all you should have one 24pin brick of wires. This is made up of 20pin block plus 4pin block.
If your computer mainboad requires 24pins of power then take the 20pin block and add the 4pin block to it. If not then just use the 20pin block.
Then there is the 4pin CPU power brick. Can only go in one way.
This 4 pin block is not to be confused with the other 4pin block found on the 24pin brick.
Lastly there are 4pin Molex, SATA and stiffy connectors, they can also only go in one way.
If it all fits in then you should be alright.
CPU: 4pin
Mainboard: 20+4pin
Hard drives: Molex or SATA power
damnor01
Jan 29, 2011 | HP Pavilion a335w (Refurbished...
Cpu fan stop few second after starting pc
Hello,have you installed new motherboard or CPU?
Follow these steps again
1) Disconnect the power cord from the back of the computer & open up the case.
2) Wear an anti-static glove or at very least discharge your static by touching a metal surface or power supply
3) Disconnect the main 20pin ATX power connector from the motherboard & the square 4pin ATX2 power connector
4) Remove any PCI cards you have & disconnect ALL drive cabling from the MOTHERBOARD. Also disconnect any internal USB fly leads from the motherboard.
5) You should now have ONLY the cpu+heatsink/fan, memory & video card installed. Locate the round silver battery in the bottom right corner of the board. Just below it, you'll see a plastic jumper cap. This cap should be covering 2 pins (pins 1 + 2) with pin 3 bare. It will be marked JP1. Move the jumper to cover pins 2-3 instead. Leave in this position for about 30 seconds, then return the jumper to its original position (pins 1-2).
6) Reconnect the square 4pin ATX2 power connector & the main 20 pin ATX power connector. Make sure that the case speaker or buzzer is connected also.
7) Make sure the only external devices connected are the keyboard/mouse & monitor. Reconnect the power lead & power on the system
Let me know what happens
Feb 06, 2010 | ASUS M2N68-AM SE2 Motherboard
CASE DISASSEMBLY
first unscrew the cover of the computer, then
i suggest you take out all the connectors, so that you can dettach the power supply easily.remove the screws at the back of the power supply, which is in the back panel of the cpu chassis.
unplug the 24 or 20 pin connector from the cpu and all the power cords that supply the peripherals, take out the power supply and replace with a new one.
Plug the screws, plug the 20 or 24 pin power connector into your motherboard, and supply devices like your hard disk, cd rom by plugging in the power cords.
note, if your computer has a 4pin connector, make sure that you plug it in.
Heres a video tutorial on the step by step process.
http://www.youtube.com/watch?v=Y_Ch2Tdj1fM
hope this will help you out.
Thank you: )
Aug 09, 2009 | E-Machines T2885 PC Desktop
Old power supply no good. bought this dynex 400 watt atx cpu power supply and need to know how to connect wires as there are some plugs that can go in multiple spots.
as long as you have the 20 or 24 plug in and the 4pin square plug in plus the hard drive dvd floppy fans i donot no your motherboard or graphic card so i cannot say anymore only next time write down your conections before removing power supply or get manual for your pc
Jul 30, 2009 | Dynex 400-Watt ATX CPU Power Supply
Ga-m61sme-s2l motherboard always shut down within 5mins
It sounds as if the motherboard is having a temperature safety shutdown. This occurs when the temperature of the CPU exceeds a certain limit.
First off: Please check your CPU fan, power supply fan, and graphics card fan(if you have a gfx card) that they are working. If not, I would highly recommend replacing the fans or at least cleaning them and attempting to get them started by rotating them manually.
Please enter your BIOS (See Here for instructions) and navigate to "PC Health Status" - check the entry for the CPU temperature. While in the BIOS there is little strain on the system, but if the temperature is above 40 degrees Celsius in this state it may be prudent to check the fan setting. Also, check if there is a CPU Fan fail warning/CPU warning temperature - on average the limit should not exceed 60-65 degrees Celsius, max. Set any Fan speed or mode settings to maximum if able.
Try again.
If problem persists, and you are sure the temperature is not too high and/or the CPU fan is working, it may be the power supply itself. It is possible for the power supply to shut itself off in extreme cases such as when a power supply's fan stops working, and the temperature of the power supply rises to an unsafe level. Sometimes the fan will work initially but quit after a certain time. The fan requires replacement if this is the case.
Let the computer sit for a while and check to make sure it is at or near room temperature. Attempt to restart the installation process. When the power is cut, feel where the power supply meets the case to check whether or not it is particularly hot.
Replacement of the power supply's fan should solve that problem. I recommend taking it to a repair shop.
If that is not the problem, a last resort is that the harddrive is overheating and causing a system crash. With the case open, start the computer (mindful to be careful and always touch a large metal object such as the computer case itself before getting your hands near any components to prevent static damage), and wait for it to crash. Place your hand gently on the harddrive. If it is very warm or hot to the touch, most likely the harddrive's actuator arm, circitry, or data plate is malfunctioning and the drive should either be taken to be repaired or replaced.
If none of the components in your computer are particularly hot, please come back with more information on your computer, such as the parts, what you are cd you are booting, any new hardware, etc.
Dec 16, 2008 | Intel Motherboard
Hello, I have an E-machine D4362 that has started intermittently shutting down. I did some troubleshooting & found the CPU and case fan not running while the machine is up & running, the CPU heat sink was...
POWER CONNECTOR ON MOTHERBOARD HAS GONE BAD. CHEAPER TO REPLACE BUT CHECK MANUFACTER TO SEE IF UNDER A WARRENTY.SOME WILL GIVE CREDIT ON A NEW BOARD.
Nov 29, 2008 | Computers & Internet
Gigabyte GA-M59SLI-S5 Motherboard Logo
47 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
