Question about Whirlpool GR2SHKXKS Top Freezer Refrigerator
IS THE COMPRESSOR THE PROBLEM?
Refer stopped cooling problem not electrical is it worth fixing?
  • 5 more comments
  • SNGMAN4 Apr 15, 2009
    thank you...pulled out a good deal of wool from the back and front of the evaporator...fans are both working...uncovered the coils in the freezer...not cold...felt compressor... no hum...hear the occasional click from the compressor area and when i cut power to the appliance heard a click a few seconds later. ??
    i guess i mean condensor coil were woolly...the ones down low in the unit near the compressor
    WOULD A COMPRESSOR START KIT FIX MY PROBLEM?
    your advice takes me back to my original question...is this 8 yr old unit worth fixing? the compressor is 200 bucks plus plus
  • SNGMAN4 Apr 16, 2009
    for 318 dollars i would have several duplicate parts the it looks to me and why the tank?
    thank you, i am very busy with other things right now and lucky for me i have a working back-up but i will do the things you suggest in the next couple of days and i think i will order the start kit and cap. i appreciate the advice and i will let you know what happens.
  • SNGMAN4 Apr 17, 2009
    you must be talking to someone else
  • 61 Answers
I think ur compressor problem .the solution is replace the compressor
Posted on Apr 17, 2009
    Brigadier General:
  • 3,614 Answers
To correct this problem, unplug the appliance and disconnect the water supply. Remove the water line where it enters the valve--usually at the bottom edge of the unit. Locate the wire strainer and remove it. Clean the strainer with a stiff brush, using mild household detergent. Reassemble the component in reverse fashion.
Posted on Apr 16, 2009
    Guru:
  • 462 Answers
If you can describe the problem in detail maybe I can offer an opinion.
  • Farley Redfield
    Farley Redfield Apr 16, 2009
    I have a better grasp of your problem reading the previous posts. Let me answer your question this way. Are you positive the compressor will not start. Allow me to give you some hope and maybe save your refg.
    If a compressor is tight due to linear expansion from heat a tip worth
    remembering is as something cools it contracts, except for water at freezing. A
    few times I have gotten a compressor to start after leaving it off for 6 to 12
    hours then retrying it. See the compressor unless left off for 6 to 12 hours
    and sometimes as long as 24 hours may have expanded parts from heat. About 1/2
    the time it is ok after new start components are installed with a start
    capacitor and relay. The other 1/2 the compressor will be ok for a day or 2 then
    stop again. A “hard spot” in the movement of the internal parts in the
    compressor, and stopping on this hard spot it can’t overcome the “tightness”.
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    If your wondering how to check out your refrigeration
    compressor;
    Modern Compressors have two operations that have to work
    together just to run. More items must be considered for them to work and work
    efficiently in systems. The 2 areas that must work together are electrical and
    mechanical. IF Either your compressor is mechanically broken inside or the motor and or start
    components are not working properly with the motor electric side, sorry, it is compressor time..
    Electrical
    Ohm the compressor terminals to ground and across to
    each other.
    1. If any read anything to ground the compressor is bad. If
    not go on to the next step.
    2.Your readings between the compressor terminals should all
    be different and you should have 1 low 1 medium and 1 high resistance reading.
    Add the low and mid reading together and the sum should be
    close to the highest reading. If it reads say 20% more or less then retest it a
    couple of times to confirm your not slipping on the terminals. If you get only
    2 readings don’t panic wait 24 hours for the motor to cool off for sure and
    recheck it. If still no reading then your compressor motor is open. A new
    compressor or replacement of the appliance is required. If you now get the 3
    readings described make a diagram you feel comfortable with as to where the
    wires go to each component before removing anything, then continue:
    3 Assuming the above checks out: Get a new *Start relay *start
    capacitor if so equipped relay *external overload and *run capacitor if it has
    one. In other words everything that is external and attached to the wires or
    terminals on the compressor or wiring per your diagram and replace them on to
    the compressor. Then if it starts problem solved if it still does same thing
    the compressor is bad (broken mechanically inside the compressor) and you have
    to decide to replace compressor or replace the refrigerating compressor be it
    AC or Refrigeration.(all these parts will be less than $30 to $100 and its sure worth the try for a compressor)
    *May or May NOT have this component:
    *Start Relay:
    MOST 99.999…% of refrigerators of the household type have a
    start relay of some kind and they vary in size shape and color. It plugs directly
    onto the compressor. SOME AC units but not all have one and it is different.
    These Resemble a box about 2”X2” X 3” with at least 3 terminals on it and these
    3 terminals are marked 1, 2, & 5. Each of these will have at least 1 wire
    on them and there may be other terminals (4 & 6) as well that can be used
    with several wires on each.
    * Start Capacitor
    100% of AC and Commercial compressors that use a start relay (and remember some do not have one but those
    that do…) and only some domestic refrigerators use a Start Capacitor. At least
    2 wires going to a black (usually) cylinder which is the start capacitor. Start
    Capacitors ALWAYS HAVE 2 or more Wires and ALWAYS HAVE TO HAVE A START RELAY.
    *External Overload
    MOST 99.9% of Household refrigerators, 80%+ of smaller commercial
    refrigerators, and most 90% of window unit AC’s but almost no central AC
    compressors Have an external overload. Those that do not have an internal
    overload. These vary in size and color and description a basic one is round 2
    wires and generally black about quarter size USA AND IF USED ALWAYS MOUNTED ON
    THE COMPRESSOR with the other wires and terminals there.
    *Run Capacitor
    Some domestic refrigerators (can be a small rectangular box)
    medium and larger refrigeration and (99.999%... of all) AC central and Window
    units have a compressor that requires a run capacitor. These type units also
    have a fan motor that can require a run capacitor. These Capacitors always have
    at least 2 wires and often 3 or more if the capacitor also is wired to the fan
    motor.
    If you follow most of these steps above you will arrive at a
    correct diagnosis well over 90% of the time ( allowing for what is unusual or
    for misunderstandings)
    30 years of doing refrigeration and this has not changed..
    Please rate me as high as you can and ask me to clarify
    anything you don’t understand.
  • Farley Redfield
    When you say "problem is not electrical" I assume you mean the power to the fridge is OK. Now check power on to the compressor. The problem may be electrical with in the refrigerator.
  • 6,784 Answers
HI, here are the components that are needed to repair this unit.
Run capacitor, compressor $41.40
Start relay, compressor $29.60
Relay and overload, compressor $32.75
Start device, compressor $35.40
Compressor tank $179.75
Total price for these commpressor kit components will be $318.90
If you can find a replacement fridge that is less than $318.90, i would buy it. If not, it would make since to purchase a compressor kit.
Posted on Apr 15, 2009
    Brigadier General:
  • 3,917 Answers
After analysing the various troubleshooting done and the symptoms provided its practically logical to go ahead and replace the compressor.
Thanks
    Scholar:
  • 145 Answers
Here is a great link to a few tips on how to fix the issues. I have had this problem once myself before and the solution about cleaning the coils fixed me :)
http://www.applianceaid.com/frig_notcold.html
Hope this can fix you-
If none of those fix it for you then you are probably looking at a relay problem with i would estimate about 50-75$ for the part and probably 150-200$ for the labor of a repairman
Please Rate
Ge Refeigerator not cooling anymore
You should compromise with repair guy,may he is anice person
Jan 21, 2015 | GE Refrigerators
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Trane xe 900 compressor operates and blower motor stops
You need new compressor (doesn't worth to repair old one). Take a look on amazon: Amazon com Trane air conditioner compressor. I hope this was helpful. cheers
Mar 16, 2013 | Heating & Cooling
I have a Whirlpool ED25RF refrigerator that stopped cooling. Lights work. At first i noticed the freezer would be completely melting items the refreezing eventually the whole unit quit working; refer
sounds like your compressor was failing with a bad contact and has now stopped working, will cost as much to repair as replace. At least newer fridge save costs in electricity, yeah sucks to have to buy another, sorry not much else you can do
Jun 09, 2012 | Whirlpool Refrigerators
Refrigerator is 18 years old and just stopped cooling. Nothing working except for the light. Worth fixing?
No, it isn't worth fixing. The parts will probably cost as much as a new refrigerator (or at least a significant fraction (50%+) of that cost). In addition a newer refrigerator will be more energy efficient and thus you will gain the money back in a few years of electric bills.
I hope this helps.
(I am assuming that this is a household refrigerator, not a commercial one.)
Sep 24, 2010 | Refrigerators
My refrigerator turns on and off i hear clicking sound.the compressor dont stops and then after a few seconds it runs again
my parents have a ge refridgerator tfx27e that is not cooling as of this morning. we had repair place out and they said the compressor is bad. per his words, he tested it and said electric is going to the compressor, but when it tries to turn on, something inside is stopping it so it won't run, needs new compressor.
the issue is, this is in a custom kitchen and the fridge has wood paneling on the front and matches everything nicely. i'm afraid a new fridge will never work with the panels made for this one?
it it worth fixing? i'm also pretty handy, but the repair guy said it's a 5 hour job. advice?
read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/558327-ge-refridgerator-tfx27e-not-cooling-bad-compressor-help.html#ixzz3pttwtbob
May 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Dec 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My (very old) Beverage-Air MT45 refrigerator just stopped cooling. The compressor seems to switch on, then immediately turn off. Is the compressor bad or just the start circuit? Anyone know how to...
turn it off let it cool go to parts house get a pro41 relay if that don't work the compressors frozen is it less than 5 years old it may be under warranty
Aug 02, 2009 | Refrigerators
203c2181p003....fridge not cooling and ice maker not working
check the relay and overload connected to the compressor. that will stop the unit from cooling. if that is not your problem, you may have a leak, which are hard to detect just by looking, and not worth fixing. it may cause less for a new one.
Jul 19, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Jun 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool GR2SHKXKS Top Freezer Refrigerator Logo
82 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
