Question about Panasonic KX-T7630 Corded Phone
Can not figure out how to change the time on the phone
The power went out over the weekend and the Time is not correct on the phone anymore and i was wondering how i go about setting it to the correct time.
Clock is not in the phone, its in the PBX!
You must set the Time in PBX.
Press "PROG"
Press "*", "*"
Enter password (default 1234)
Press "0", "0", "0"
Press "ENTER"
Set Y-M-D
Press "NEXT"
Set Time
Press "ENTER"
Press "CANCEL"
Press "EXIT"
Posted on Apr 22, 2009
How do you change time from DST to standard Time
you can go into the settings for your device and turn DST to "On" so it shows the correct time if your gps is not doing it automatically for you. You can check to see if it has the latest firmware loaded in it. Since the weekends for the DST were changed a couple of years ago some gps's may not change the time at the correct weekend.
Nov 03, 2009 | GPS
HOW DO YOU SET THE DATE AND TIME?
It should be in 'settings' on your cell phone menu. Search around your phone. It could also be in 'organizer'. On my old one, it was in 'organizer', and once I went there, there was a 'set date and time' button. Here is the answer from the Vtech website: "Make sure the answering system is on. Press [Time/Set]. The system will announce the current clock setting, then announce "to set date and time, Press Time/Set". Press [Time/Set]. Press [Change] until the system announces the correct day, then press [Time/Set]. Press [Change] until the system announces the correct hour, then press [Time/Set]. Press [Change] until lthe system announces the correct minutes, then press [Time/set]. The system announces the current clock setting. Note: You can press and hold [Change] to advance the mninutes in increments of ten. "
Jun 06, 2009 | Vtech Lands Phones
Need to reset Time/Day on it
This should do ya.
http://dstech1.com/changing-time-on-a-partner/
May 18, 2009 | Avaya MLS 18D Corded Phone
LG600G did not update time for daylight savings time
I had the same problem. I simply powered it off, and powered it back on, and it had updated.
Mar 10, 2009 | LG Shine KE970 Cellular Phone
How to change time on Olympia Infoglobe caller id
I have the manual and can tell you what it says:
(this worked for me last year when we went off daylight savings, but for some reason, It doesnt seem to work anymore. I can't imagine that I did anything different then. You can try, though.)
Enter (or leave) the Demonstration Mode by pressing the right key for at least 1 second.
Then, by pressing SELECT key, you are SUPPOSED to be able to scan a menu which lets you pick date format, time format, etc.
This no longer works for me, and the instructions also have a contradictory comment that says the SELECT key is disabled in this mode. But perhaps this will work for you.
I would also appreciate instructions if anyone knows what I am doing wrong.
Mar 08, 2009 | Olympia InfoGlobe Caller ID
I am trying to set time and date on a calculator
OK, I bought one over the weekend just for chuckles. I figured it out.
On the top of the calculator there is a key that shows a little clock. Punch it once and the date appears...like 01-01-2000 or somesuch. Press it again and the time shows up..
Hold the time set key (=) down for a second until the first zero starts to flash. All you have to do is start punching in the time. When you are done press the time set key again. Voila!
Punch the key with the little clock again and the date shows up. Hold down the time set key for a second like explained above until it starts flashing. Enter the date with the key pad numbers. Done!
I couldn't figure this out either till I looked above each key (didn't notice what it said). Anyway, look real close.
Hope it works out for all and everyone finds this solution...
CMHIMG
Mar 04, 2009 | Canon P200-DHIII Calculator
How do you change the date on executone 64 phone? Our power went off & it reverted to Jan 1. I was able to change the time, no problem, but can't figure out how to change the date. Thanks!
Step 1: Press Menu key
Step 2: Press Park 3 key
Step 3: Enter password followed by # key ex. 543#
Step 4: Enter 9819
Step 5: Enter date with # in between. Ex. 01#26#2009#
Hopefully this will solve your problem.
Jan 26, 2009 | Executone 64 Corded Phone
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
Day light Savings time problem
Hi ... I have the same problem ... I found this link but I haven't tried it out yet ...
http://www.emersonradio.com/dst_g2.htm
Oct 27, 2008 | Emerson Smartset Clock Radio
Samsung lcd 12b keyset dcs
http://www.tel-programmer.com/Time%20setting/samsung_time.htm
Jun 23, 2007 | Samsung DCS 12 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
145 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
