Question about Electrolux Refrigerators
Electrolux rm4271 3 way caravan fridge.240v trips out straight away,checked heater element resistance....470 ohms.12v supply works ok,gas igniter sparks...but have removed from caravan....so no gas supply to test.
5 Suggested Answers
SOURCE: Electrolux RM 4270 caravan fridge
Thankyou for your assistance, but i found the solution with electrolux direct.
Hope to use your site again sometime.
Posted on Aug 05, 2008
SOURCE: Our caravan fridge electrolux rm4206
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Posted on Feb 07, 2009
SOURCE: measurement of defrost heater elemnt resistance in E 442B
yes, should be 165
Posted on Aug 06, 2009
  • 1796 Answers
SOURCE: Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
Posted on Apr 19, 2010
Why is it tripping?! what can i try next? thanks
Is their not two elements, one at the top too? If it is tripping on the high limit switch it could be the thermostat Try checking the grounding of the unit.
. http://en.wikipedia.org/wiki/Residual-current_device
Jan 14, 2015 | Water Water Heaters
Electrolux rm 4200 repair
Try 1,000 Volts, proceeding up to 10,000 Volts. I'm sure something will happen.
Sep 18, 2014 | Refrigerators
Why does my caravan fridge trip out when connected to 240v
The heater element is almost certainly to earth. Work it on gas until you can fit a new heater.
Jul 01, 2012 | Refrigerators
Electrolux 3 way fridge will not work on 12v or 240,switch lights up, ok on gas. can i repaire?or have i got to replace? i think the model No is rm4200 or rm4230
Hi My three way fridge has the same problem. Have solved the 12v problem as it was not wired to the 12v invertor. Do you have an on board battery supply? the 12v is usless and runs a battery flat in no time. Better off to use gas. Hope to have the electrician here next week to check 240v so will let you know if we find a problem. Graham.
Jul 07, 2010 | Electrolux Refrigerators
Electrolux fridge in my caravan will run on gas,
Hi it sounds time to pull it out and give the ignition box a good blow out to remove dust and cobwebs. Also remove the jet in the supply pipe where it screws on to burner box. Just wash and clean it dont poke anything in the jet hole. Graham
May 13, 2010 | Refrigerators
My 3-way Dometic fridge works on gas but stopped working on 240V! ....Why?
With the 240V element diconnected, test it with an ohm meter to find it was open circuit. No heat! The 12v element still had resistance.
At the moment gas is still keeping my cool while I wait for a new element to arrive. ..... cheers
Sep 01, 2009 | Dometic RM2652 Refrigerator
I have a Thetford N112 which will not cool the
un plug the heating element from the circuit board and ohm it out. also check fuse on board. but sounds like the heating element has gone out. if when you ohm it its on 0 its bad
Aug 27, 2009 | Refrigerators
Refrigerators Logo
1,078 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
