Question about Samsung HP-T4254 42 in. Plasma Television
Screen has light red tone in black level - Samsung HP-T4254 42 in. Plasma Television
    Novelist:
  • 159 Answers
Sparkling red pixels. or misfiring pixels.
There is a chance to adjust the screen. has to be done for an authorized service center. Call them and find the closest to your area.
Posted on Apr 14, 2009
Mercedes benz 2004 vito 111 fog lights not working front only come on when switch is in rear position but no rear fogs i have checked all fuses is there any way to check switch ?
The only way to test the switch is to take it out of the dashboard and disconnect it.
Using a multimeter set to continuity, (yellow circle), or Ohm's, (Green circle), place the black probe to one terminal and the red to another. Move the red to each of the other terminals in turn watching the meter display. Move the black probe and repeat moving the red probe. Do this for all the terminals on the switch, in all of the switches positions.
If the switch position is working you will get either a tone or numbers on the display. If the switch position is closed OR faulty you will not get a tone and the display will show 'O.L' (means open line).
The off position will always give you no tone, ( displays O.L) . A single action switch will give you only one pair of terminals as a tone, (displays numbers). A twin switch will give you two pairs of terminals as a tone, (displays numbers).
Feb 15, 2018 | Mercedes-Benz Cars & Trucks
Motorola 9500 sat phone wont turn on, red light comes on.
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 28, 2012 | RIM Research In Motion Blackberry Storm...
Calabrations settings for 40es6100
Try this:
Picture Mode Movie
Backlight 16
Contrast 95
Brightness 45
Sharpness 15
Color 50
Tint G50/R50
ADVANCE SETTINGS
Dynamic Contrast Off
Black Tone Off
Flesh Tone 0
RGB Only Mode Off
Color Space Auto
10pt White Balance On
Gamma +1
Expert Pattern Off
xvYCC Off
PICTURE OPTIONS
Color Tone Warm2
Digital Noise Filter Off
MPEG Noise Filter Off
HDMI Black Level Low
Film Mode Off
Auto Motion Plus Off
LED Motion Plus Off
10PT WHITE BALANCE
ON
Interval Red Green Blue
1 0 -1 -1
2 -1 -1 -1
3 0 0 0
4 -1 0 +1
5 -1 -1 +1
6 -1 -1 -1
7 -1 -1 -1
8 0 0 0
9 +1 0 0
10 +2 0 0
WHITE BALANCE
Setting Value
R-Offset 25
G-Offset 25
B-Offset 28
R-Gain 18
G-Gain 23
B-Gain 21
SCREEN ADJUSTMENT
Picture Size Screen Fit
Sep 03, 2012 | Samsung Televison & Video
Wiring
There are 3 wires on this siren. Red, Black, and Yellow. The red and black wires will give you the normal sound you hear from a siren. If you hook up the black and yellow, it will give you a continuous long tone. Normally, you hook up the black to Bell - and and the red to Bell +.
May 19, 2011 | Siren Dsc Sd 15w Ulf Surface Mount Siren...
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
Intercom green and red light flashing with no tone
go to setting open tone setting option check weather volume level is high or low and check your current profile is in silent mode or in genearl mode, if it is in silent mode means change it in to general mode.
Dec 26, 2010 | Cell Phones
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Overiding Empty Cartridge error for Dell A10 962
Red flashing light on '8BK' small black cartridge on left hand side.
If this indicates 'low ink' then it is not alerting me on the monitor. I think this is something different because my printing has been interrupted. Aileen
Dec 13, 2007 | Office Equipment & Supplies
DISPLAY
Your phone's screen connectors might have a problem and need to be replaced by new ones or they need to be placed correctly. this might have happened due to a fall of your phone on the ground.
Oct 07, 2007 | Nokia 6670 Handheld
Samsung HP-T4254 42 in. Plasma Television Logo
184 people viewed this question
Jerry Greenberg
Jerry Greenberg
