Question about Bose 901 VI Main / Stereo Speaker
Bose 901 mk11 no sound . i have checked all connections, swapped speakers over.
  • zaki2 Apr 30, 2009
    thanks guys i found the problem one of the drivers is blown. i have gone across the terminals and all is working ok. just need to replace the driver. zaki 152.
  • OnlyOneN
    OnlyOneN May 11, 2010
    Have you tried removing the equalizer unit from the signal path?
  • 3 Answers
Since that u swapped l/r speakers already,it might not be ur speakers,if u wanna make sure ur 901s are working,feed a 1.5 v battery power to ur speakers,,(device a connector,piece o wire ,etc) if the speakers makes ticking sound upon contact,u got continuity.now..ur eq..make sure it its working,,(see instruction manual)lastly..confirm that ur amp which is powering ur 901s is emitting sound.(hook up a different speaker)
Posted on Jun 12, 2009
Bose 901 equilizer connections to sansui G901DB
It sounds like you may have only the 901 loudspeakers, and not also the companion 901 equalizer box. You must install the 901 equalizer properly--using the tape monitor loop of the G901 receiver. If you of not, the 901 loudspeakers will perform poorly.
Jun 17, 2014 | Bose 901 VI Main / Stereo Speaker
Screeching sound from Bose 901 Equalizer
Check the treble on the EQ, is it possible to take a pic of the equalizer?
May 27, 2013 | Audio Players & Recorders
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
Bose 901 eq connect to mixer and amp
how to connect bose 901 speakers to mixer. help me
Mar 29, 2012 | Bose 901 VI Main / Stereo Speaker
My left side speaker is not working i suspect fuse blown but where is the fusebox situated on my BOSE 901series III.
There is no fuse in a 901. Have you swapped channels, speakers, bypassed the EQ to ensure it or its pathing has no part in the failure?
Oct 28, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 no sound
Give a little bit more info about your rig. What amp, how connected (I assume you ARE using the Active EQ in a Tape Monitor loop or between the pre-amp and amp), Both speakers failing, just one? What works? Did it ever work?
Apr 14, 2009 | Bose 901 VI Main / Stereo Speaker
Onkyo tx sr 705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Sep 13, 2008 | Bose 901 VI Main / Stereo Speaker
Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
in order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Feb 13, 2008 | Bose 901 VI Main / Stereo Speaker
Free booklet/part #149393
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jan 10, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Nov 28, 2007 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
161 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
