Question about Dell (2336V) Motherboard
Hey my computer turns on all three fans are spinning and i hear a beep and then nothing no display nothing its really annoying ps:im no expert at computers so i dont no what the single beep means or one beep and then 10 secs later another beep. please help i want to play sims 2 again.
  • 326 Answers
One beep is good. Multiple beeps is not good.
Most likely you have a loose connection.
Generally if not the connection, the monitor has gone dead.
Possibly you have a defective Video Card
Unfortunately, you may have a defective System.
The first two are generally the cause of such problems.
Check all your connections in the back of the machine. A large Blue or White rectangular connector should be going to the back of the machine, these are color coded so the plug will go in, only one direction in only one port.
After making sure you are connected check your monitor power cable, assuming you get no Lights on the monitor at all.
After that: You may have to assume that either the monitor is dead, or that the video portion of the system is dead. This would require that you either replace the Video Card in the machine. If you get more then one single beep, you may have this problem
Or
This will require that you replace the System Board, if you are getting more then one Single beep you may have this problem.
Please let us know when all the connections are in order, so we can better diagnose the issue.
Good Luck
Posted on Apr 14, 2009
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
When i turn the power on, 3 beeps play, the fan runs and the power light comes on, but nothing else
Hearing ONE beep is normal, and a signal that the computer hardware is OK.
Hearing THREE beeps is a signal that something is wrong:
* burnt-out CPU,
* one of the fans is not spinning (clogged?) or spinning too slowly (about to seize-up),
* one of the RAM chips is defective
* the video-card is not working
If there is more than one RAM stick, remove all but one stick, and start it up, to see if it starts.
Check that the fans are spinning freely.
Dec 14, 2010 | Gateway GM5260 PC Desktop
My PS3 wont start games when im signed in on PSN
HI I HAD THAT PROBLEM SO I ASKED THE EXPERT..HE SOLVED MY PROBLEM! BASICALLY THERE A CORRUPTED DATA ON YOUR COMPUTER WHICH NEEDS FIXING.
QUICK STEPS: PLEASE NOTE YOU MAY LOSE YOUR SAVED DATA SO BEST TO BACK UP SYSTEM TO A USB FIRST.
ONCE YOU BACKED UP YOUR SYSTEM FOLLOW THIS STEPS ONLY IF YOUR SURE. THIS WORKED FOR ME, IT WORKS 90% OF THE TIME SO I WAS TOLD BY THE EXPERT. REALLY DEPENDS ON HOW MUCH DATA HAS BEEN CORRUPTED.
QUICK STEP:
  • TURN PS3 TO STANDBY BY PRESSING THE BUTTON THATS ON THE CONSOLE..HOLD THE BUTTON,YOU WILL HEAR FIRST BEEP THEN ANOTHER BEEP 5SECONDS LATER, THEN THE THIRD BEEP. HOLD BUTTON DOWN UNTIL THE LIGHT TURNS RED THEN MOVE FINGER.
  • NOW SWITCH ON PS3 HOLDING POWER BUTTON ON THE CONSOLE..HOLD THE BUTTON DOWN YOU WILL HEAR FIRST BEEP THEN ANOTHER BEEP 5 SECS LATER, THEN TWO BEEPS TOGETHER.LET GO OF BUTTON WHEN YOU HEAR TWO BEEPS.
  • IT SHOULD SAY SOMETHING ABOUT CORRUPT DATA. AGREE TO IT. SOON YOU SHOULD HAVE A 6 OPTION MENU COME UP.
  • PRESS NUMBER 3...RESTORE SYSTEM FILES
  • IT SHOULD THEN RESTART COMPUTER.
  • NOW TRY PLAYING YOUR GAME ONLINE.
  • ITS MEANT TO WORK AS IT DID FOR ME.
IF IT DOESNT WORK THAT MEANS THERES ANOTHER PROBLEM. I WOULD ADVICE YOU TO ASK THE EXPERT. THEY TELL YOU STEP BY STEP, THEY FIXED MINE IN HALF HOUR. ITS WORTH EVERY PENNY.IF THEY SOLVE YOUR PROBLEM THAT IS! HOPE THIS HELPED YOU GUYS...GOODLUCK!
Jul 30, 2010 | Sony Playstation 3 (PS3) Console
My compaq laptop F500 has black screen when power on
That sounds like a power supply problem. That would be the first thing I would check. If it was the processor, you would have heard a long beeping sound or if it was the memory you would hear about three 'annoying beeps'. The main reason you indicated there is no display on the screen and that the fan spins for a few seconds then shuts off, would hint that power is not going to the mother board long enough to spin the processor or cooling fan. Hope this helps :)
Apr 17, 2010 | Compaq Presario 700 470024-192 Notebook
Fujitsu lifebook n5010 notebook won't reboot i let the battery run out while working. next day, turned on three loud beeps, then three loud beeps then fan runs but no display on the screen. power off,...
Okay, sounds bad.
However, take out the battery from the laptop and remove mains lead. Go and make tea! Then, drink it. Once you have complete this task.
Plug in the AC lead ONLY into the laptop and then try to power it on.
You should see lights on the Hard Disk LED or hear a beep. If you see them but nothing on the screen at all when booting then the capacitor pack has probably gone on the screen. This is not an expensive part, but you do need to know what you are doing to replace it. Think it time to give it to the workshop or ask IT bod to look at it for you.
Oct 26, 2017 | Fujitsu Siemens Lifebook N5010 Notebook
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
Buzzing sound in Acer Aspire 5535
I've come across this before and it turned out to be the soundcard driver. See if there's an updated driver on Acer's website.
Strange buzzing can also be caused by a stuck or damaged key. Does pressing ESC help at all?
Unlikely to be the hard drive. They crunch and grind but don't buzz, unless they're completely knackered, when they can give you a three-tone buzz sound and won't spin up at all.
Hope that helps,
Matt
Aug 24, 2009 | Acer Aspire 5535-5050 Notebook
No POST from my MSI Motherboard
Hey dude when u are turning on ur computer is it making a really shrill beep and nothing is coming up on the screen? if so why don't u try opening the ram and then putting it in again or just putting a new ram in.
Oct 23, 2008 | MSI K8MM-V Motherboard
ASrock beep sounds???NO display
hi cathy
please specify
1.- pc?
2.- os
3.- model
and the properties about this
example... hard disk, ram, proscesor...
i think the problem is any hardware but i need more data
Oct 21, 2008 | Asrock Computers & Internet
Front control panel shows "Remove Probe From Oven" & Beeps.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Sep 23, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Dell (2336V) Motherboard Logo
67 people viewed this question
Alun Cox
