Question about Cycling
Had a bike accident and now my front wheel has jammed and I dont know how to fix it.I think my front brakes are the problem. Any advice would be greatly appreciated.
  • 469 Answers
The wheel is likely bent and rubbing on the brakes, this is assuming you have caliper brakes on you bike. If so remove the wheel, hold it by the axle and give it a spin, if it has alot os wobble in it it will need to be trued at a shop.
Posted on Apr 15, 2009
1998 Suzuki GSX600F, i recently got knocked off my bike and i have had to strip the callipers and clean them out as the brake was unbelivable spongy. i have put then back on and bleeded the brakes as...
Are you sure the discs or calipers wernt damaged or bent in the accident.
You dont normally need to strip them to bleed air.
If the seals are not leaking, probably wont help to replace them
Jul 27, 2011 | Suzuki GSX 600 F (Katana Motorcycles
I have rockhopper sl, just taken the front wheel off for the first time, and accidently pressed the brake lever now the pads have locked and i cant get the wheel back in, please help, is it safe to use a...
Don't use a screw driver. That means you have hydrolic brakes. Take it to a bike shop. It is relatively difficult to open w/o damage it is easy to damage. Also, pick up some disk brake spacers that you put in when you remove the wheel to prevent just this problem.
Jul 14, 2011 | Specialized Bicycle Components Specialized...
I took front wheel off bike to fix puncture. i
Loosen up the hub nuts. Center the wheel between brake pads. Put something like a screw driver in the space between wheel and frame to keep the wheel centered and not moving as you tighten the nuts.
Oct 02, 2009 | Cycling
Brake pads dont retract
you will need to retract them with a small c clamp, thus slowly pressing the calipers back into cylinder.plz rate-bozcro
Sep 16, 2009 | Avid Juicy 7 Hydraulic Disc Brake 2008...
Seems like front brake engaged
Is yr bike fitted with disc brakes to the front?
If yes thn you will have to overhaul the brake calipers, it seems the pistons have jammed in there probabely due to rust on it at the pitted areas.
Better still is to overhaul the brake mastercylinder too.
Good luck
May 25, 2009 | 2000 Suzuki GZ 250 Marauder
Front wheel wobbles
More than likely the wheel is out of true. There are 2 choices,
1 Buy a spoke wrench and attemp to true the wheel. You can do this by spinning the wheel to locate the spot where the wheel goes furthest to one side then tighten the spoke coming from the opposite side. Do this slowly 1/2 turn at a time. Do not over tighten the spoke. It may be necessary to loosen the other side slightly.
Alternate spokes between both sides of wobble.
2 Take bike to a good local bike shop to be tuned and have the wheels trued. Most shops offer a tune up at low cost. A well tuned bike will last a long time.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 06, 2009 | Freestyle Mongoose Bmx & Owners Manual -...
R1 abs?
A new US study has found that anti-skid brakes dramatically reduce the chances of a fatal bike crash.
Anti-lock braking systems can reduce the likelihood of a fatal bike crash by 38 per cent, a new US study has found.
The study, by the Insurance Institute for Highway Safety, found that anti-lock brakes dramatically reduced the chances of overturning a bike and crashing.
A separate study, by the affiliated Highway Loss Data Institute, found that insurance claims dropped by 21 per cent for bikes fitted with the technology.
In a report on the study, the president of both organisations, Adrian Lund, says anti-lock brakes are life-savers.
“It’s a way to reduce the chances of overturning a bike and crashing, so it can save lives,” says Lund.
While the introduction of ABS on cars didn’t deliver any noticeable reductions in fatal car accidents, Lund says it’s clear that widespread adoption of the technology on bikes would have a much bigger effect.
“It isn’t surprising that anti-lock brakes are more beneficial on motorcycles than they are on cars because the two-wheelers are so much less stable and it’s this instability that leads to crashes,” he says.
The braking process on a bike is more difficult than a car because the front and rear wheels typically have separate braking systems. The front brakes are more effective for stopping fast, but hitting them too hard can make the front wheel lock up and pitch a rider off the bike.
Lund says that some bikers hold back on the brakes for fear of locking up, only to find they haven’t braked hard enough to avoid a collision.
ABS systems use sensors to adjust the brake pressure continuously, ensuring that the wheels never lock up and the rider can continue to steer in an emergency.
The HLDI study compared insurance losses for 12 brands of bike with and without anti-lock brakes, finding that insurance losses were 21 per cent lower and claim frequency was 19 per cent lower with ABS models.
The IIHS study studied eight brands and found there were 6.6 fatal accidents per 10,000 registered bikes without ABS and 4.1 accidents per 10,000 for bikes with ABS.
In a statement released to coincide with the study findings, local bike insurance specialist Swann Insurance says the studies support its call for more car-like safety items to be included on motorcycles.
Nov 10, 2008 | 2008 Yamaha YZF-R1
Brake pads jammed on rear cycle wheel
Hi Moon river,
Make and model of the bike pls?
May 12, 2008 | Air Purifiers
Cycling Logo
83 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
