Laptop shuts off after 15 minutes, even when plugged into wall outlet. fan runs quieter than normal
Computer shuts off after about 15 minutes, with battery plugged into wall outlet. fan is quieter than normal
  • 326 Answers
Most likely the system is going into standby or hibernating.
Check the Control Panel for Power Options, And adjust these accordingly.
If it is a Dell system, you may want to check your QuickSet options as well for these will often take precedence over your OS settings.
Let us know
Good Luck
Posted on Apr 14, 2009
Dell Inspiron 5720
F-8 is the key, Try to "cold start" the computer, meaning remove the power plug from wall outlet or uplug from computer, remove battery, now replace battery and plug computer into wall outlet. Push the on button while "TAPPING" the F-8 key repeatedly Tap, tap, tap, until you hear a beep or it load the black menu with safe mode options. IF THAT DOES NOT WORK: shut down the laptop,remove AC supply, remove battery. Plug the AC power back in,DO NOT INSTALL BATTERY, Start the machine, without battery installed, and tap F-8 repeatedly. If it still fails, PULL THE PLUG OUT OF THE WALL OUTLET WHILE THE COMPUTER IS STILL RUNNING. NOW PLUG THE LAPTOP BACK INTO THE WALL AND START, THAT SHOULD TAKE YOU TO A BLACK PAGE WITH WHITE SCRIPT WITH OPTIONS YOU ARE LOOKING FOR.
Oct 31, 2012 | Dell Computers & Internet
Tip
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
It continues to shut down after start saying it is full, but it has no water in it. No matter if I take out the bucket and push back in it still says full. Not even a year old!!!
Here's a solution that often works. Turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and set your control as you normally do. Hopefully, that 12-15 minute timeout allowed the unit to reset itself. If it continues to do this contact Haier Customer Support 877-337-3639 and have your Model Number and Proof of Purchase handy. If it's less than a year old, it's still under warranty.
Good lick. I hope this helps solve your problem.
Apr 18, 2011 | Haier DE65EJ Dehumidifier
I have a dell Inspiron 1705, it runs fine, boots fast, runs normally however after about 10 to 15 minutes of use the laptop freezes. The only way to reboot it is to hold down the power button to shut it...
Looks like an overheating problem.
First, make sure that you put your laptop on some hard surface. If you put in on your bed for example, the soft surface will block the air vent on the bottom of the laptop, resulting in poor cooling of the inner components.
Do you hear the fan working, and air blown out of the exit vent on the side (or rear) of the laptop?
If not, then perhaps the fan is broken and needs replacement.
If the fan can be easily heard, working at full speed all the time, there is a problem with blocking the air inlet, or the internal radiator/heatsink got covered with dust and lint, and needs cleaning - try compressed air blown from the opposite direction (from the air outlet) to blow away the dust - of course with the computer switched off, otherwise you'll be "fighting" the fan trying to blow in opposite direction. If this doesn't help, the laptop needs servicing, as it probably lost the heat-conductive layer between the processor and heatsink.
Jan 23, 2010 | Dell Inspiron E1705 Notebook
Fan keeps running for 15 minutes after engine is shut on my Hond
Either relay will have to be replaced or the sensor. They usually run mabey 5 minutes top afterwards.
Aug 28, 2009 | 2000 Renault 181
Have power cord plugged into asus eee machine and wall outlet. light has been blinking all day. when asus eee gets unplugged it shuts off.
lets try this ---
* turn of your computer
* remove the plug from your computer.
* Remove the battery from your computer
* Let it sit for 3-5 minutes
* Replace the battery
* Plug your computer back in (Make sure the wall outlet is working as well, seems simple, but have seen it before)
* Let it sit for about 3-5 minutes
* Boot your computer
* go to
Start -> Control Panel -> Power Options -> Power Meter
Note the Total Battery Power Remaining
* Let your computer sit for 15-30 Minutes and see if the Total Battery Power Remaining has gone up.
If so problem solved
if not you may be time for a new battery.
Dec 26, 2008 | Computers & Internet
Laptop turning off
Often, if a system turns off every time at roughly the same time, it's a hardware problem. System gets too hot, shuts down, restart it and it'll run again for a while, but not quite as long, and continue like that. Can you feel/hear the fan moving air? Possibly clogged, see what you can do to get it cleaned up a bit. Does it make any difference what surface it's on? May be covering a vent on the bottom or back.
Oct 29, 2008 | Sony Computers & Internet
Help please
You may have a short in the power connector on the mainboard. Try wiggling where the power cord plugs into the notebook and see if it cuts out.
A glitchy power supply could do it, especially if it's putting out too much power, or does it when it warms up a while. When the notebook cuts out, leave the power supply plugged in and test it with a voltmeter, it should match the rating on the power brick. A reputable electronics shop or computer shop could test it also. Get a recommendation; stay away from any chain stores.
Apr 26, 2008 | Computers & Internet
Laptop
Are you saying it shuts down even when you're plugged into the wall?
Dec 19, 2007 | Acer TravelMate 2300 Notebook
Condensor?
It probably shut off on high pressure. Let it cool down, plug your hole that you drilled and give it another try. The water is suppose to collect there and the fan is suppose to throw it into the condenser to keep it cooler and make it run more efficiently. Good Luck,
kstfas
Oct 09, 2007 | Frigidaire FAH106N1 Wall/Window Air...
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
271 people viewed this question
David Payne
David Payne
