Question about Canon Optura 200MC Mini DV Digital Camcorder
Problem with loading cassette
When I load a cassette in the camera, the LCD screen flashes "remove the cassette". So I opened the cassette compartment and the strip of the cassette is out--a little bit struck inside the camcorder. I've tried to load several cassettes but every time, it does not work!!! What should I do?? Thank you
  • 217 Answers
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 14, 2007
Mvx200i didn't load cassette
Are you putting the cassette in the correct way round ?
Jun 17, 2017 | Canon MVX200i Mini DV Digital Camcorder
I push the tape in as to load it and it immediately pops back out.
Your camera is experiencing condensation - your LCD should have a flashing image of a red droplet (this is a condensation warning). REMOVE THE CASSETTE to avoid damaging it.
Another cassette CANNOT and SHOULD NOT be loaded when condensation is detected.
Leave the cassette compartment open - its takes an hour until the water droplets evaporte. After the condensation warning stops flashing, wait for 1 more hour before resuming use.
Jun 22, 2010 | Canon XL2 Mini DV Digital Camcorder
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Loading a cassette
having the same problem...when I put a new tape in it just ejects it right away!
Apr 17, 2008 | Canon ZR200 Mini DV Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Cassette warning
The switch is board monted and is actuated by the loading compartment when it is closed near the rear of the cabinet. It requires an extensive tear down to remove the board before the switch can be replaced. There are other problems that occur also. Does the drum spin up? If so, then the tape is rcognized but its another problem. Good luck, magic seadog
Aug 12, 2007 | JVC (GRAXM18US) Camcorder
When pouring a chilled beverage into a glass, water droplets may form on the surface of the glass. This happens because the air around the glass is rapidly cooled down, and moisture in the air adheres to the surface of the glass. This phenomenon is called condensation. This kind of condensation may also occur with camcorders. If you continue to use the camcorder with condensation on it, it could damage the camcorder. Condensation may form on the camcorder in the following cases: (1) When being moved from a cold place to a warm place (2) When being used in a rapidly-heated cold room (3) When being used in a humid room (4) When being moved from an air-conditioned room to a warm, humid place When condensation occurs: The camcorder stops operating automatically after its power lamp flashes. The warning message "CONDENSATION HAS BEEN DETECTED" appears and the condensation-warning icon below starts flashing. Condensation-warning icon If a cassette is loaded, the warning message "CONDENSATION HAS BEEN DETECTED" and "REMOVE THE CASSETTE" appear and the cassette-warning icon starts flashing. Cassette-warning icon If a cassette is loaded in the camcorder, remove the cassette immediately and leave the cassette compartment open. If condensation is detected, the POWER switch and cassette-removing switch will be activated. Leaving the cassette in the camcorder may damage the tape. A cassette should not be loaded into the camcorder when condensation is detected. How to avoid condensation Unload the cassette and place the camcorder in an airtight plastic bag when moving to locations where temperatures vary. Allow time for the camcorder to adjust to temperature changes slowly before removing it from the bag. Resuming use Allow at least one hour before resuming use; more time may be required for heavier condensation. When condensation has been eliminated, turn the camcorder on. After the condensation-warning icon stops flashing, wait one hour before resuming use.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon Optura 200MC Mini DV Digital Camcorder Logo
305 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
