Question about Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum
Vacuum cleaner when we turn the unit on the spinner brush does not turn the belt is still on the brush but how do you get to the other end.
  • 625 Answers
Go to thehooverstore online. here you'll find an exploded diagram of your machine and how the belt is installed.
Posted on Sep 22, 2007
SOURCE:
How come brush doesn't spin while on vacuum cleaner
First of all, check that your belt isn't broken, it is a rubber belt that goes around one end of the brush and to the motor shaft. Next, check to see that on each end of the brush isn't clogged with hair and or dust fuzzy stuff. If so, you will have to remove the brush and take off each end and remove all debris, then reassemble and don't forget the rubber belt to the motor to make the brush turn. Good luck.
Jul 31, 2014 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Brushes not rotating
If your unindentified vacuum cleaner is an upright, the belt may be stretched and unable to rotate the roller brush. The roller brush ends could be clogged with debris, preventing it from rotating freely. The solution is to disconnect your vacuum cleaner from the power and turn it upside down for inspection. It may be necessary to remove the roller brush and remove the end caps to clean inside. Replace any worn parts
May 07, 2013 | Vacuums
Trying to change the belt
things you will need Vacuum belt
  • Screwdriver
  1. Locate and purchase the correct belt for your Eureka vacuum cleaner from the local grocery or department store. Vacuum belts come in different sizes according to your model of vacuum. Check your owner's manual or the vacuum itself for your model number.
  2. Turn your vacuum cleaner over so that the bottom of the unit is facing you. Remove the cover plate from the bottom by undoing the screws that are holding it in place with a screwdriver.
  3. Locate the belt pulley rod near the back of the vacuum base coming out of the motor. With the vacuum cleaner base turned upside down and facing you, the motor and pulley rod should be up near the top of the base.
  4. Slide the vacuum brush roller out of the slots at the bottom of the vacuum base and remove the old belt from the brush roller and pulley rod. With the brush roller off of the unit, clean the brush by removing any strings or cords wrapped around the tube.
  5. Install the new belt by looping it over the belt pulley rod next to the motor and then looping around the end of the brush roller in the belt slot. Hold the brush roller and pull back on it to tighten the belt while you slide the roller back into the slots on the vacuum base.
  6. Replace the base cover plate by snapping it back into place and securing it with screws. Turn vacuum back upright and turn it on to test the belt and verify the unit is working
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
The brushes will not turn
Check to see that there is a belt around one end of the brush -- belt may be broken. If the belt is intact, let me know and we'll go to the next step.
Charlie
Feb 01, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The unit does not put any watter on the carpet and when I push the triger the red spinner does not move. The tank is full of hot watter
This sounds like your pump brush belt is broken in your Bissell. The belt controls the pump in the machine, as well as the brushes. This would be explain why the solution is not spraying, as well as why the red spinner on the top of the machine is also not spinning.
Here's an extremely helpful video that you can watch on how to replace the belt on your Bissell ProHeat Carpet Cleaner.
If you open up the door and find that your belt is not broken, please just reply using the Clarification Request form here on the Fixya website, and I'll be more then happy to do some advanced diagnosing with you to figure out what the problem is.
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt:
http://www.bissell.com/VideoRating.aspx?id=1555
If this information was helpful to you, help other Fixya users with the same problem find this video by clicking the very helpful four thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Can't get the belt to engage for carpet cleaningwith my riccar
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum2_bing.gif cleaner is unpluged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unsrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift staight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners2_bing.gif agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continously having to replace belts2_bing.gif. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, posistion the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Thank you
Chris Jones
GoVacuum
Jan 17, 2010 | Riccar 8850 Vacuum
It turns on but the spinner underneath wont work now
Turn the vacuum so the bottom is facing up..
Take out the scews in the plate that surounds the brush and take it off..
The belt should be firmly on the brush and the motor..
If the belt has come off the motor - pull out the side of the brush that the belt connects to.. Put the belt back on the motor post and the brush.. It might be a tad tough going back in because the belt should have a little tension..
Once the belt is on and brush in place - put plate back on..
Hope this helps ;o)
Jul 15, 2009 | Bissell 3576 CleanView II Bagless Upright...
The brushes will not turn. How do I open the unit to put the belt back on?
Hoover doesn't use belts on their steam cleaners. Either the shaft that is on top of the brush block broke off, or the turbine is bad. The turbine is what turns the brushs.
Jun 12, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
My eureka
The belt may look ok, but am sure it is stretched and when this happens, the brush roll won't turn like it should. Did you check the brush roll ends to see if they turn freely, if not replace it.
Mar 10, 2008 | Vacuums
Dyson vacuum cleaner DC04
I would suggest you invert the vacuum and remove the plate covering the spinning brush assembly. You should check the belt located on one side of the spinner brush to see if it is worn or broken. Also remove anything wrapped around the brush that could be affecting it. Ensure the brush is free to rotate and seated correctly. If the belt is worn or broken, or the spinner brush is unable to spin, replacements are available from a licenced repair facility. I hope it helps! Good Luck!
Jan 29, 2008 | Vacuums
Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
99 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
