Question about RCA 24F512T 24" TV
Snowy picture The Cable connection on the back of the TV pulled out and has a short wire attached. I have found where the area that it goes but cannot see any place where it was it has been connected before. Please help
    Genius:
  • 1,153 Answers
You will need to know how to solder to fix, depending on the set, some have a stand alone tuner and others an onboard tuner and if it's stands alone then you can order a new tuner, but if it's onboard(meaning apart of the whole board) you have to resolder. Hope this helps! You will need to solder the thin wire inside to its broken part and the outside piece to its ground. and the two cant be touched or bridged.
Posted on Sep 13, 2007
SOURCE:
Snowy screen on my lenovo
You have the 'snowy screen' option enabled. If you press the Fn key down, and tap on the S and C key, Santa Claus will dance across the screen............
WHAT? !O_O!
You gonna' believe that? lol!
You need to diagnose. However the problem is a loose connection of Video Cable.
Loose at motherboard side, or LCD screen side. Could be Video Cable is damaged also. (Stretched/Broken wires)
What is the model number? It's on the bottom of the laptop. I should be able to get you the link to the HMM. (Free) (Hardware Maintenance Manual)
Then if you wish I can step by step guide you, through the diagnostic procedures, and disassembly required to access both connections, of Video Cable.
Also can guide diagnosing through a diagnostic flowchart
Post back in a Comment
Regards, joecoolvette
Apr 21, 2013 | Lenovo Computers & Internet
Tuner is out. Menu works, but TV has a snowy picture.
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Jul 29, 2009 | Zenith H20H52DT TV
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 10, 2009 | Sony Televison & Video
Snowy picture
A snowy video indicates that your input signal is relatively weak. On the other hand, a noisy picture is when there are too much interference is super imposing on the video.
Snowy picture comes about when the signal coming in the RF INput (Ant/Cable) at the back of the unit is below a certain level. If this is the case, then it is not a problem with your TV but rather your aerial (antenna) or the cable from your provider. A way to verify that it is the ant/cable that is the cause and not a defective TV/tuner is to hook up an old VCR set to Ch. 3 or 4 to the RF IN of your TV using a short 75 ohms coaxial cable terminated at both ends with FP-5 connector. Play a known clear good tape and set your TV to Ch. 3 or 4 as the case maybe. If the picture is relatively clearer, better, then you have just confirmed that it is indeed your aerial or your cable (provider) that needs looking into. If on the other hand, the VCR signal is also snowy then chances are that you have a problem with the input stage of your TV including possibly your tuner.
For your aerial problem, antenna orientation or replacing with a higher gain antenna might help solve the snowy signal. For your cable problem, you have to call-in for service from your cable provider. If it is a TV problem, your best course would be to seek the services of a qualified TV technician since this involve electronic circuitry analysis, diagnosis and possible component replacements.
Additionally, you may try looking for any loose connection, loose grounding, broken wire or anything out of the ordinary in your connections.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 12, 2007 | RCA P52926 52" Rear Projection Television
How do we adjust our tv
You didn't mention anything about a cable box, VCR, etc. which might be connected. A snowy pic. means simply, inadequate signal is reaching the tuner, or the TV tuner itself is bad. If the first is so... check your cabling. If you have a VCR or DVD player hooked in between the cable box or outside antenna (whichever is the case), VCR (RF or ant.) out should go to the TV, VCR antenna (RF or ant.) input to the cable box. Also check the cable wire itself. If you look at the end of the cable, you should see a relatively thin center wire. This center conductor is what carries the signal. If it is missing, bent over, or too short to make contact with whatever it is connected to, you will have a very snowy pic. If you have a spare TV, connect it in place of your "new" TV, to narrow down the problem. Lastly, if all is well with hookup, cabling, etc. the TV might have a problem. Sometimes the tuner has a component defect, or the coaxial connector can be broken.
Sep 25, 2007 | Televison & Video
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Toshiba 36" Television
no unless U are capable of soldering within the tuner
Dec 10, 2006 | Toshiba 35A44 35" TV
While watching tv, the tv all sudden goes snowy, no sound, and have to turn it off and back on to make it work again
Connect up another set right next to that set thats going out to make sure the cable or that line is not bad. It soukds as though you may have an intermittant tuner assembly inside the TV set. Its also a possablity that there could be a bad solder connectiuon in or around the tuner assembley. Not really a job for the user, as this set has hot and cold chassis, and can give a mean shock if you do not have the know how to work on these monsters. good Luck PS Please do not forget to rate this thread.
Dec 08, 2006 | RCA Scenium D40W20 40" Rear Projection...
RCA 24F512T 24" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
