Question about Fuller Brush FBPTCAN Bagged Canister Vacuum
I have a clogged hose. How can I take it apart to get the clog out? or what can i stick up it to get it out?
  • 105 Answers
Most vacuum cleaner hoses can be unplugged at some point. One way to clear a clog is to reverse the hose & let the vacuum **** the clog out the way it went in. If you have to remove the clog manually, a length of coat hanger wire, with a small hook bent on one end, will serve. Most clogs are near the hose ends, so not much wire length is required.
Posted on Apr 14, 2009
    Master:
  • Fuller Brush Master
  • 894 Answers
HI, it's Jim from Crucial Vacuum!
If your Fuller Brush Vacuum is experiencing problems with the hose a simple fix is to detach it from the vacuum itself. On the far end of one side of the hose there should be a button to remove it.
Stretch the hose out as far as you can, this will help loosen any clogs as well as provide more durability with your hose. A handy device to use to unclog hard to reach spots in your vacuums hose is a broom handle. This will unclogging easy by running the broom handle through the entirety of the hose.
You can purchase your replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
www.CrucialVacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
Posted on Dec 09, 2014
3 Suggested Answers
deme-tri
  • 90 Answers
SOURCE: How can I unclog my shop vac hose? I tried to blow
try a water hose to flush the stuff out
Posted on Sep 14, 2009
rylee_smith
  • 8619 Answers
SOURCE: clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
Why is my hoover spirit spitting dirt out the sides?
Hey there! Sounds like you have a clog somewhere in the vacuum. Try removing the hose completely from the cleaner. Use a broom stick to gently loosen and remove any clogs from the hose. Use a wooden spoon to break up and remove any clogs from the lower hose area. Also check that your bag is not full and your brushes are still spinning. Hope this helps!
Jun 03, 2014 | Hoover U5068-900 Sprint Upright Vacuum
How to remove a clog
Hey there! Most of our vacuums you are able to remove the tool hose without the use of a screwdriver or other tools. Follow these brief steps to check your vacuum for clogs.
Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
Remove the hood or nozzle to access the brushes, remove the brushes. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose
Hope this helps you!
Jun 01, 2014 | Hoover Vacuums
I have a Hoover nano cyclonic vacuum. I completely lost suction and found the hose was clogged to the max. After removing it and changing the filter I tried to use it and it picked up dust but not much...
If the hose was clogged there's a good chance the head was clogged too. Try to stick a bent coat hanger or other semi-rigid piece down the throat at the top of the head to push the clog out through the mouth. You might have to remove the beater bar to get the clog out.
May 20, 2014 | Vacuums
Lost suction but no cloggs in line
see the solution; God bless you
How to determine a clog in your hose
Take your central vacuum hose and connect it directly to the dirt canister. After turning on the vacuum if the hose has normal suction here then the clog exists in your tubing.
Click here for help with tubing clogs. But, if you experience reduced suction at the canister then your hose is clogged. See Solutions below.
check.gifPlug hose in reverse into the inlet located on your unit and turn on the system. This should aspirate the clog out.
check.gifOr, remove the hose from the inlet and push a garden hose through hose to push out the clog. Most importantly, the garden hose must be turned off and there should be absolutely no water entering your vacuum hose.
check.gifOr, remove the hose from inlet and drop in a heavy object such as a screwdriver to push out clog.
Jul 23, 2012 | Broan-NuTone VX475 Bagged Central System...
The dirt isn't making its way to the canister . . . what could be the problem? I have taken apart everything I know to take apart to check it.
Generally this is due to a clog in the hose.
Disconnect both ends of the hose, hold one end up and drop a coin into it. Raise the hose so the coin should drop out. If it doesn't there's a clog. It can usually be pushed back out with a broom stick. Push toward the powerhead end.
A blockage in the powerhead above and behind the brush will also cause this. One here can usually be pushed out using a wooden spoon handle.
Is there even suction at the power head? Drop a bit of paper on the floor and try to vacuum it up to find out.
Jan 29, 2011 | Dyson DC14 All floors Bagless Upright...
Hoover tempo upright is clogged. I can only vac for a few minutes, then I have to unplug it and turn it over and clean out the under part under the roller. It is totally stuffed with dirt and dust and...
Disconnect the hose and head and wands. Drop a quarter thru the hose, the handle sometimes clogs. peer thru the wands and inspect the elbow on the head for blockage as well
Sep 04, 2009 | Vacuums
There is no suction from the hose on a Kenmore Destiny Plus Vaccuum Cleaner
there is clog in the unit. Either the bottom or in the hose. If you can take hose off, stick hose on end of broom handle and push out clog.
Jul 09, 2009 | Kenmore Canister Vacuum Vacuum
Suction
hello tnwalkergal the hose may have a clog inside the hose at the bend you can take the hose loose and run a broomstick or a yardstick thorgh the hose this is how I find the clog
Jan 24, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Clogged Hose
Hi, this sounds like you have something stuck quite firmly in the hose!! If you use a good sturdy stick then you should be able to move the object without any damage to the hose. Check along the outside of the hose first just incase something has pushed its way out of the hose wall.
Get back to me.........
Jan 02, 2009 | Electrolux Centralux Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Fuller Brush FBPTCAN Bagged Canister Vacuum Logo
1,106 people viewed this question
Top Fuller Brush Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Fuller Brush Vacuum Expert? Answer questions, earn points and help others
