Question about Sony VAIO VGN-FS742/W Notebook
No power THE DC PORT GOT DAMAGED. threw regular ware.. and i baught a new one with the specs for this model.. put it back together and it will not even power up. is there a reset on it or something... help... or is it a mother board problem
  • 155 Answers
Before assuming the worse, let us assume it is a damaged DC jack. This can be replaced by expert personnel and it costs less than a motherboard replacement.
Posted on Apr 15, 2009
How to disassemble charging port aspire 6935g
Before you disassemble the computer to determine if it is the charging port; have you had the power brick tested? It can easily be checked with a multi-meter. If so; checkout YouTube. Google Acer DC Jack replacement and watch the videos. The majority of the computers out there are laid out pretty much the same. It will give you an idea what you need to do to replace it. Look on eBay for the replacement jack; it's cheap and should be free shipping.
When you remove the screws, put them in a sewing box in the order you removed them. It will be easier to remember where they go when you put it back together. Also, you may want to use a video camera so you have a record on what steps you took to remove it so you can reverse the order to put it back together.
Aug 16, 2014 | Acer Aspire Computers & Internet
I need a Linkco MC-316 power cord hook up to my Waring fryer. Can you give suggestion?
I also went crazy looking for this part! I even went to the waring website and tried to figure out which deep dryer I had that would match the 4 diff. chords they have as replacements, then I discoverd smallappliance.com' "finally", an answer. they have a list of model numbers that you can choose from by model number. So i read thier instructions, went to the back or bottom of my deep fryer, found the model number, mine was DF250B, ordered the part from the list of thier model numbers and presto $14.00 later, I'm having my chord shipped to me!!!!!!!!Waring needs to do a better job putting the two together. Good luck everyone!
Mar 24, 2011 | Dishwashers
I replace the dc power jack on a toshiba satellite a215-s7437 with a radio shack dc connector soldered the jack on and put back together when I plug it in the blue adapter cord lights up along with the...
this sound like there is a short in your soldering, did you solder the port directly onto the motherboard. just go over all the joints and make sure there is no shorts
Mar 28, 2010 | Toshiba Satellite A215-S7437 Notebook
Power adapter specification ct-630
Hi - look in back or under keyboard for power specs.Then go to Guitar Center and the right adapter. GuitarCenter.com has casio power adapters.
Jan 04, 2010 | Music
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
Dell Inspiron 1501 Power Cord will not stay put
With your first problem: If the power cord is not damaged, it is most likely the DC jack in the computer is damaged. A new one can be soldered on the motherboard in most cases. It's a 50/50 chance that it will work though. The second problem: The only fix I can offer is to purchase a new keyboard for the laptop and replace it. Hope this helps.
Oct 14, 2008 | Dell Inspiron 1501 Notebook
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
Toshiba Satellite 1415-S173
Hi
DC jack replacement is easy however requires a bit care since its mounted on the mainboard. Desolder the old DC jack. Solder the new one firmly. Dont keep the soldering iron too long on the PCB as it will damage the lines and will deform the DC Jack. You can get DC jack very low cos from local repair stores or you can order from Toshiba parts depot (800-524-8338)
Please post your question if you need further assistance.
Good Luck
Feb 09, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Aprilaire 550 humidifier
You can call 1-800-955-7075 give them the make and model #.The part # should be 4217,10x113/8 frame for $14.56 plus shipping
Nov 20, 2007 | Aprilaire 550 Humidifier
Sony VAIO VGN-FS742/W Notebook Logo
112 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
