Question about Dell Latitude 830 Notebook
Ive down loaded verizon software for a pc5750 aircard, computer does not see it in the port
Check your device manager an make sure the the drivers are loaded. if not reinstall drivers and reinstall the pc5750 aircard software utility BEFORE you install the card. This should solve the problem.
Posted on Apr 14, 2009
Bagaimana cara membuat pasword di modem verizon pc5750
maaf mas ko skr jd g bisa brodband acces ya,, dan lelet banget modem PC5750 nya
Jul 24, 2012 | Computers & Internet
We borrowed a verizon usb720 aircard from a friend. Can you install and use it without the cd?
If its a product from verizon then it is linked to a network. What this means is that it has a phone number attached to it which has been programmed on the cd. It is an aircard and, I am sure, not a plug and play device (a plug and play device installs as soon as you connect to a computer without a cd) . Get the installation cd from your friend and if he/she doesnt have one, take it to any nearby verizon office to have the software installed.
Aug 30, 2011 | Computers & Internet
Hello. I own a UM175 Pantech Alltel aircard and I've heard that, using your computer, you can turn the aircard into a wireless router that can be used to connect to the internet with various devices. I...
The UM175 is not an access point itself, you could plug it into a Craddlepoint and then connect your other devices to the Craddlepoint. Testing was down with a UM175 and a Craddlepoint here:
http://www.evdoinfo.com/content/view/2421/64/
If your other devices happen to be computers, you can setup connection sharing and use instructions found here:
http://popewebhosting.blogspot.com/2009/07/share-internet-alltel-verizon-pantech.html
Jun 13, 2011 | Computers & Internet
Where do you put a verizon aircard 595 on a dell e6410?
Hi.
The AirCard 595 is a Type II PCMCIA.
With the laptop facing towards you look at the right hand side of it, down the side of the latop just above the DVD/CD RW you will see a slot with a small button to the left of it. That is the PCMCIA slot. Push that button so it pops out and then push it back in again. That will push out the blanking plate. Pull out the blanking plate and then tyou can pop in the aircard. Make sure you don't put the card in upside down and also make sure you have the driver/software CD handy.
Regards.
Jun 07, 2011 | Dell Latitude E6410 Notebook PC Core i7...
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
I have a D-Link DIR 450 which I have been using with good success with my old Verizon PC5750 card. I just got a new PC5750 card. I have my D-Link box but there is no sw in it. Is there supposed to be.
If you already programmed it, yea hit the reset hold it down for at least ten seconds. And sometimes its not your home's fault, sometimes your internet service provider has problems, it would be a coincidence but just to cover all the bases I would have them check your connection make sure its ok.
Apr 30, 2009 | D-Link DIR-450 Router (DIR450)
Default gateway problem with Linksys WRT54G3G-ST
there chat is really awesome get on with them and they will walk you thru. I just did mine... the IP for the router access was 192.168.1.1 but mine was a GS. the user name you leave blank and the password is admin. If the password does not work then hard reset by holding a pen in the the back of the router for a full minute to allow all the power to drain and memory to erase.
Once you have access to the router you can set it to anything want... I suggest you set the number of DHCP leases to be one more than you have computers for so that a guest with a wireless can access without have to set up another access and MAC Filter.
As far as the AIR card goes use a ethernet cable to connect directly to the router to make the changes. then once you are in the router you will set the exact IP and default gateway required by your device and games... you can set them and open ports too... just do not open anymore than you have to..
Good luck,
Jason
Jan 28, 2009 | Linksys WRT54G3G Wireless Router...
Verizon Wireless PC 5750 air car work in a HP Pavillion
No because the Aircard PC5750 is a PCMCIA slot card, and your laptop has a Next Gen Express Card/ 54 Slot. The Express card slot is smaller than the PCMCIA slot. That makes the PC5750 incompatible.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | HP Pavilion dv6000z Notebook
Dell Latitude 830 Notebook Logo
243 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
